I dont know what to do! HELP!
FiveOoutlaw
34
I recently got rid of my heater core and the lines that run to the firewall in my speed density lx because of a leaky core. I capped the water pump and moved the temp sensor to the lower intake. All was going well until I started it up and the idle will not come down from 1500, I unplug the sensor and the idle drops back to 800 like normal. But when unplugged it runs like its always cold, running really lean with backfires out of the intake and missing alot.
I tried a new sensor hoping it was a bad one, no luck. PLEASE HELP!!
here is what i did, (i didn't run an EGR spacer so i had to cut my coolant rail)
cut the coolant rail about half way down so you can still put that sensor in, then just "loop" a hose around to connect the two ends.
thats not exaclty what i did cause i NEED my heater core up here for the chilly mornings, i just cut mine and ran to rubber hoses to the fire wall.
cause i think the sensor is getting a false reading from the lower intake
just a thought
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
ok..... what i am trying to say is, put those steel lines back on and cut them just after where the sensor is, so you can still put that sensor in. then take a peice of coolant rubber hose and "loop" a hose so it bypasses the heater core, this way the sensor is stil in the same spot. i have seen guys not cut it and just loop it around the back of the motor. i cut mine so i could use my TB with no EGR spacer
here is a half assed scetch i made
