  • SN95 4.6L Mustang Tech
I have a problem?!? What could it be?
  • Thread starter Thread starter MustangGT305
  • Start date Start date Aug 23, 2009
M
MustangGT305
Miami
Aug 23, 2009
  • Aug 23, 2009
I have a 2002 Mustang GT I was driving yesterday and I got a "check engine light" when I got home I plug in the Diablo Predator and check what was the check engine light for and appear me "P1000" OBD System Readiness Test Not Complete. and "P1152" Lack of H02S21 Switches-Senson Indicates Rich (see P2198). those are the two trouble code I got. Also my car is acting funny, it kinda shakes when u press the accelerator. What could it be? Has anyone had this problem before? Those anyone know the solution? I try to clear the codes but the car still acting up plus them the codes appear again.
LastCallRacing
Premium Sponsor
Dec 4, 2008
172
San Diego, CA
Aug 24, 2009
  • Aug 24, 2009
Could be a bad O2 sensor...I'm guessing at this honestly, but the symptoms do seem to point to something related to that. You could also have a really dirty MAF sensor. Check all your connections too. You'll have to do some diagnostics on this one. What all was changed before it started doing this?
trinity_gt
3,125
81
99
Canada
Aug 24, 2009
  • Aug 24, 2009
As you've probably surmised, one of your O2 sensors is reading a voltage that indicates a "rich" mixture and it's never reading "lean." Typically, the output of an O2 sensor is ~850mV for rich and ~250mV for lean. If the sensor is "locked" or stuck rich, the PCM recognizes this and flags the error.
The P1000 means that the PCM can't finish a test cycle of all emissions components because of this error.
Sounds like the driver's side (B2) front O2 sensor or wiring under the car has an issue of some sort.
Any work done to the car recently? Exhaust? Headers? Mid-pipe?
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
