Hey guys,
This is a combo I've been kinda dreaming up for the past year or so. Its gonna be a while before I can build it because its gonna be a big costly and I have a baby on the way right now. But I still would like to know what you guys think of it and what kind of power you think it could make. I'm also open to suggestions. When I build it I want to do it right the first time. It will be a weekend street toy that might see some occasional passes at the strip. I would be putting it in the coupe in my sig. Here it is:
CHP Dominator Big bore 428W
AFR 225 heads
Custom cam from FTI(Ed Curtis)
1.6RRs or whatever size Ed suggest
Spyder intake
90mm TB
MSD dist., coil, & ignition
Aeromotive 1000hp fuel system
not sure what size injectors I would need
not sure what size MAF
Spec twin disc clutch kit
T56
3.55 or 3.73 gear
31 spline Moser axles and Detroit Truetrac diff.
I'm not sure I want use a solid or hydraulic roller cam. I want to shift somewhere in the neighborhood of 6800-7000.
As for suspension:
UPR front suspension kit(K-member, A-arms, coilovers)
UPR rear kit(adjustable UCAs and LCAs)
UPR C/C plates
Eibach rear springs
Eibach front and rear swaybars
Full length subframe connectors
Minitubs...I want to be able put 335s out back and be able to switch to a nice size slick
Sorry this was so long. I'm open to suggestions, insight, whatever.
AFR 225 heads
Spyder intake
90mm TB
T56
3.55 or 3.73 gear
As for suspension:
UPR C/C plates
Eibach rear springs
