• Community Forums
  • The Welcome Wagon
I just joined
  • Thread starter Thread starter JK.
  • Start date Start date Sep 18, 2026
First Prev 2 of 2
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,342
1,550
133
San Diego, CA
Sep 24, 2026
#21
  • Sep 24, 2026
  • #21
If i'm going through the effort of removng the trans and all the stuff that has to come off to get that out, i'm going all in and replacing everything i can in there like others have mentioned. Unless removing the trans is no big deal and you've done it a bunch of times.
Reactions: nickyb and JK.
J
JK.
25
11
Mays Landing New Jersey
Sep 24, 2026
#22
  • Sep 24, 2026
  • #22
I've done engine swaps and things like that but I haven't done anything of the sorts on my car like that
Reactions: gkomo
nickyb
I gotta say i never painted my nuts, Never Ever
3,065
1,680
163
nevada
Sep 24, 2026
#23
  • Sep 24, 2026
  • #23
What's that saying ?
Buy once , cry once.
Reactions: JK.
keel
292
135
53
Seattle, Wa
Sep 24, 2026
#24
  • Sep 24, 2026
  • #24
Done it a bunch of times? Yes. Still really sucks every time.
Reactions: gkomo
J
JK.
25
11
Sep 25, 2026
#25
  • Sep 25, 2026
  • #25
any tips?
keel
292
135
53
Seattle, Wa
Sep 25, 2026
#26
  • Sep 25, 2026
  • #26
JK. said:
any tips?
I would invest in some impact rated wobble sockets or u-joint sockets for the trans to bellhousing bolts. And extensions. Those are probably the toughest fasteners to get to.
One good tech tip that I learned is that even if you drain the trans fluid its a good idea to plug or cover the area where the driveshaft yoke goes in or it will drip everywhere which is very annoying especially if you don't have a lift and you're under the car lying on the ground. I stick an old worn out driveshaft yoke in there and that works well but there are dedicated tools too or you can always just use a plastic bag.
Also if you have long tubes you can get the bellhousing off without taking off the headers by loosening the motor mount bolts and rocking the engine backwards. This can also help with clearance with the shifter if you don't want to remove that either but my car was manual swapped so I'm not sure if that applies to factory stick cars since they have a slightly different trans tunnel.
Reactions: Potomus Pete and JK.
J
JK.
25
11
Sep 25, 2026
#27
  • Sep 25, 2026
  • #27
that's a big help to me thank you.
Reactions: keel
General karthief
Mod Dude
Aug 25, 2016
28,135
10,755
213
polk county florida
Sep 25, 2026
#28
  • Sep 25, 2026
  • #28
Wobble sockets and safety glasses
Reactions: JK. and DadLife0724
J
JK.
25
11
Sep 28, 2026
#29
  • Sep 28, 2026
  • #29
this weekend I'm gonna do the ball joints, Inner and Outer tie rods, the struts, and the bearings and seals on the axle cause the bearing and seal is going on the driver side.
Reactions: General karthief and gkomo
J
JK.
25
11
Sep 29, 2026
#30
  • Sep 29, 2026
  • #30
I was driving this morning and while I was driving I'm pretty sure the clutch went or is going out. Because it was a loud squeaking noise so idk it it was the throw out bearing going and not the clutch but I need a little bit of input so I don't go through the whole thing and end up replacing the wrong things.i was already planning on replacing these things this weekend but not in the middle of the week.
keel
292
135
53
Seattle, Wa
Sep 29, 2026
#31
  • Sep 29, 2026
  • #31
Are you sure the squeaking is coming from your clutch assembly? If it is your throwout then the sound should change when you push the clutch pedal.
J
JK.
25
11
Sep 29, 2026
#32
  • Sep 29, 2026
  • #32
yea i’m sadly positive it stopped making the noise when the clutch was pushed in and it was smoking so my clutch is now screwed
keel
292
135
53
Seattle, Wa
Sep 29, 2026
#33
  • Sep 29, 2026
  • #33
Yeah ok it's time to service that stuff. Unless you have to I wouldn't drive the car. Take it apart when you can and replace all the typical wear items like the pilot bearing and throwout bearing, but take a close look at everything since these cars are old. The first time I pulled my trans I ended up replacing the clutch fork, pivot ball, and input shaft bearing retainer which are not typically wear items but all showed signs of needing replacement.
These parts are all readily available and relatively inexpensive, but I will say, these cars sure do love to nickel and dime you to death...
J
JK.
25
11
Sep 29, 2026
#34
  • Sep 29, 2026
  • #34
unfortunately i was going to school when this happened but i live only 5 mins away from it so its not all bad im going to replace a good amount of things on it
Reactions: DadLife0724 and gkomo
Potomus Pete
I'm still waiting for the fully nude shots
5 Year Member
Mar 7, 2019
3,350
1,247
153
Sarasota Florida
Sep 29, 2026
#35
  • Sep 29, 2026
  • #35
Get a transmission jack. Harbor Freight, and its so much easier. Almost not fair if you've done them on your back.
Reactions: nickyb and DadLife0724
J
JK.
25
11
Sep 29, 2026
#36
  • Sep 29, 2026
  • #36
way ahead of you
Reactions: DadLife0724 and Potomus Pete
First Prev 2 of 2
M
new member
  • markmoon
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 24, 2026
General karthief
M
Old/new guy
  • mustangtoby
  • Aug 17, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
Just joined up !
  • Bigred1971
  • Jan 2, 2026
  • The Welcome Wagon
The Welcome Wagon May 11, 2026
Bigred1971
A
New Member in Georgia
  • Amyj94GT
  • Jul 24, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 24, 2025
AeroCoupe
L
T5 compatibility on a 81 notch
  • lench23
  • Nov 10, 2026
  • The Welcome Wagon
The Welcome Wagon Monday at 2:17 PM
KRUISR
  • Community Forums
  • The Welcome Wagon
