  • 1994 - 1995 Specific Tech
I must be nuts!
  • Thread starter Thread starter BlackVert
  • Start date Start date Sep 1, 2004
BlackVert
5,589
9
98
Bethesda, MD
Sep 1, 2004
  • Sep 1, 2004
I have this C&L 80mm Mass Air Meter housing that I got like a year ago for my 1996 GT. It has the blue tube which, according to C&L, means it is calibrated for the stock (19lb) injectors.
So I had this great idea to try installing it in my 1995; it happens to fit fine and the electronics bolt up to it just like it was made for the 1995. but ... obviously noone has a maf transfer function for it, since it was made for the 1996 (EEC-V) and I am putting it on a 1995 (EEC-IV). Damn that K&N filter is big ...
Well, I installed it today during lunchtime, and sure enough, my car runs like crap with the stock maf function. Not surprised. Actually I was surprised it ran at all - in OL it seemed sort of OK, but after it warmed up and CL kicked in, I could barely keep it running. I read in the CNL80MM transfer function (that came with TwEECer v1.30A9) into my calibration and I am going to reset the computer and put in the new function before trying to go home after work.
After work, I put in the CNL80MM transfer function, and the car started out OK. About 5 minutes into my drive home, I came up on a traffic jam and as I was decelerating, the car died. I was able to get it started again but I had to almost floor it to keep it running. Then mysteriously, it was OK again. I was datalogging and I noticed that the KAMRFs were not moving and the LAMBSE values were stuck at 18.30, so I figured that I was running way too rich.
After I got off the highway, I pulled over and leaned out my MAF about 40% across the board. It seemed much better, but now it was going off scale low (lean), so I richened it up again. I am now at a max reading of 1722 kg/hr, and my KAMRFs and LAMBSEs are both moving again. So I guess I am getting closer to where I should be.
Next thing to try: take the "CNL 73mm 55mm electronics" function and "Richen" it by 9.59% (80/73=1.09589). This gives a function very similar to what I ended up with (top kg/hr=1738.5)
The throttle response seems much better so far, but I have been afraid to really step on it.
I can't decide if this whole endeavor shows my bravery or foolishness ...
- chris
AznStanger3v
2,026
Northern VA
Sep 1, 2004
  • Sep 1, 2004
good lord man, you are intent on having that beast. good luck with your endeavor.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
