I need a wiring diagram for an 01
Jun 20, 2005
137
I need a wiring diagram for an 01 gt
Need to figure out how to wire in my coolant pump for intercooler, would like it to turn on when car starts. Anyone have any suggections or info for me? Thanks a lot!
I don't think you need a wiring diagram for that. How much power does it draw? Just wire it to a 12v ignition source.. a location in the fuse box would probably be your best/safest bet.
Just use a test light, and have a buddy turn the ignition on/off while you probe the area for a wire near where your pump is. If it's 12v, and isn't a huge amp hog (do you know how many amps it uses?) you can probably get away with running a straight wire. If it's over 15-20 amps, I'd say use a relay.
