I need help ASAP!!
  • Thread starter Thread starter marine_2003
  • Start date Start date Nov 26, 2005
marine_2003
427
Lake County, FL
Nov 26, 2005
  • Nov 26, 2005
I was puting in my SN 95 axles in my 8 an noticed that my Trac Lock was "broken" so i spun it around and the other side moved the same way. I put my finger inside where the pin goes and wiggled both sides. Is this normal for the unit?
I
iapexl8r
254
Nov 26, 2005
  • Nov 26, 2005
hmm I think you are talking about the spider gears (that you are moving with your fingers) sounds to me like the fiber clutches are worn. first off you should feel around the inside on the bottom of the housing for peices for metal. usually the "ears" come off the clutches. if you do decide to re bulid it there is a way to remove one steel disk from either side and install one extra fiber disk. ford sells the re-build kit. chris
marine_2003
427
Lake County, FL
Nov 26, 2005
  • Nov 26, 2005
I had no metal in the bottom of my housing. How easy is it to rebuild? or should i have someone do it? Also, I got a set of SN 95 axles with the ABS gear, does that come off? will it affect anything if i leave it on, i am almost done with my five lug conversion.
marine_2003
427
Lake County, FL
Nov 27, 2005
  • Nov 27, 2005
If i buy this Ford Racing Trac Lock rebuild Kit
http://cgi.ebay.com/ebaymotors/Ford...018166769QQcategoryZ33731QQrdZ1QQcmdZViewItem
Do i also need to buy a master bearing rebuild kit, or will my mechanic be able to pull out my trac lock, rebuild it and put it back in?
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
  • Gulftown980x
  • Jul 29, 2026
squeak93
