i need help
  • Thread starter Thread starter franknstang
  • Start date Start date Oct 17, 2008
1 of 2 Next Last
F
franknstang
11
  • Oct 17, 2008
hey guys i traded a 4 wheeler for a 1988 ford mustang gt. i cant get it to start. i have spark but no gas to keep it running. i checked all the relays and the fueses all good.. the one relay under the druver seat is not working i think ,so i replaced it, still nothing. what should i do..
thanks carl
btlfed91
42
STL
Oct 17, 2008
  • Oct 17, 2008
Can you hear if your fuel pump is working?
F
franknstang
11
  • Oct 17, 2008
nope i dont here it
FrankenStang
Now, give me a damn CT!
4,461
70
129
Florence, Az
Oct 17, 2008
  • Oct 17, 2008
Welcome to Stangnet... ummm... franknstang.
I bet it's the fuel pump if you don't here it prime when you turn the key on.
btlfed91
42
STL
Oct 17, 2008
  • Oct 17, 2008
Do you know if the fuel pump has ever been replaced thats where I would start have a buddy listen for it when you turn the key on and if still cant hear it I would check the connector at the pump and maybe use a multi meter to see if you have power to it and work your way forward from there.And if you dont know if its ever been replaced and have plans for upgrades to the car it might be worth your while to go ahead and put a 255lph pump in it if you've got the funds,you can get a descent pump for under $100.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 17, 2008
  • Oct 17, 2008
Did you check the rollover switch in the rear next to the hatch lock behind the interior pannel?
FrankenStang
4,461
70
129
Florence, Az
Oct 17, 2008
  • Oct 17, 2008
Can't believe I didn't think of that. Good call.
btlfed91
42
STL
Oct 17, 2008
  • Oct 17, 2008
I hear ya it never crossed my mind eather!
F
franknstang
11
  • Oct 18, 2008
yea i push the button and it does noting..dont it say down or something when you push it... how many power wires are there to the fuel pump
thanks carl
F
franknstang
11
#10
  • Oct 18, 2008
  • #10
hey if the inertia switch is bad will the relay work under the seat. because i am not getting any power form ether side of the inertia switch.
2BADSTANGS
385
Colorado
Oct 18, 2008
#11
  • Oct 18, 2008
  • #11
The relay should still function normally, I believe the inertia switch cuts power to the pump at the switch itself.
HISSIN50
34
129
Oct 18, 2008
#12
  • Oct 18, 2008
  • #12
On an '88, the inertia switch is on the control side of the FP relay.
Run Jrichker's Cranks but No-Start checklist. It's in the Useful Tech sticky.
Good luck.
FrankenStang
4,461
70
129
Florence, Az
Oct 18, 2008
#13
  • Oct 18, 2008
  • #13
Here, I'll make myself useful..
http://forums.stangnet.com/6161267-post.html
F
franknstang
11
#14
  • Oct 18, 2008
  • #14
hey guys how do i do the EEC test connector and jump the connector were do i jump it to...need details... thanks carl
hotcobra03
poteet,tx
Oct 18, 2008
#15
  • Oct 18, 2008
  • #15
Neutral safety switch ?
hotcobra03
poteet,tx
Oct 18, 2008
#16
  • Oct 18, 2008
  • #16
Im in my ford books.if its a 2.3 thier is a 18 ga blue fuse link inline.does car have fog lites and do they work?
F
franknstang
11
#17
  • Oct 18, 2008
  • #17
yes thit have fog lights but dont think it works and it a 302 not a 2.3
hotcobra03
poteet,tx
Oct 18, 2008
#18
  • Oct 18, 2008
  • #18
The relay under the seat was it green?thier is also a self test connector located below brake booster.its a 4pin type.looking at plug tapers on top ,the end holes will look like upsidedown T the one on the right turn key to run use a wire and ground it pump should come on
F
franknstang
11
#19
  • Oct 19, 2008
  • #19
yea the relay is green.... and if it comes on when i do the jump them what that mean.. thanks carl
hotcobra03
poteet,tx
Oct 19, 2008
#20
  • Oct 19, 2008
  • #20
If the pump comes on u will need a fuel pressure tester.you need to know hi pressure is and does it hold pressure 4 3min after turning off.check 4 power at relay.orange with lite blue stripe should be hot. The pk/bk wire goes to fuel pump.the red with black stripe goes to inertia switch.the tan and lite green is the ground from the eec self test plug.
1 of 2 Next Last
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
