i need help
ok guys i checked the fuel pump and its good.. so now i have spark and fuel but still wont start .... it will start with starter fuel and then die.. i have gas in the fuel rail ...what should i do now
form the coil I do I have to check the plugs, I know I was getting spark from the number 1 plugs. when I put the spunk plugs in I don't get spark I replace it still the same, if its out I get spark..(theres a relay that under the hood on the passenger side, what's that for.
The ecm controls your fuel injectors.their is a ecm relay next to ecm.their is also a tester for that.a lite to plug into injectors .a test lite should work i think.c if u have power to injectors.harber frieght sells all these tools
what the relay on the passenger side under the hood is that for anything important. I know the relay by the computer, it on the top.. I will have to pick one of them test light for the injectors up.
