I NEED HELP!!
  • Thread starter Thread starter stangbang302
  • Start date Start date Feb 12, 2009
stangbang302
180
fort valley, ga
Feb 12, 2009
  • Feb 12, 2009
i rebuilt a 92 mustang with my uncle but he left early to iraq. so i have the car to myself now. what did was change out all the fuel lines power stearing lines brake line etc... we put in a explorer 5.0 motor and converted it to mass air. i took out the 4 cyl car harness and got one from a 91 gt and put it in mine. hooked up pretty much everything that i could. starter relay is hooked up running a cable to the starter. hooked up a battery and hooked up cables, tried to start start up. but nothing at all happened no lights or sounds. im pretty much in a jam right now. so any help would really be appreciated. thanks
88mouse
630
Mooresville nc
Feb 12, 2009
  • Feb 12, 2009
did you get all the fuseable links hooked up? The battery good?
stangbang302
180
fort valley, ga
Feb 12, 2009
  • Feb 12, 2009
i pulled a positive cable out of a thunderbird 5.0 looks pretty much the same to me. but i cant seem to find that fusible link off the harness. this is my first mustang. i only know so much. so bare with me if im not so smart with this lol
ID89GT
1,659
18
49
Spokane Valley, WA
Feb 12, 2009
  • Feb 12, 2009
Can be a number of things..
stangbang302
180
fort valley, ga
Feb 12, 2009
  • Feb 12, 2009
ya i figured it would be alot. but im just wanting some ideas of what it could be ya know?
stangbang302
180
fort valley, ga
Feb 12, 2009
  • Feb 12, 2009
alright so i switched the cables around on the starter relay. the lights and all work now. but the car wont crank over, cant even hear the fuel pump kick in. any help on that?
HISSIN50
34
129
Feb 12, 2009
  • Feb 12, 2009
You need to print out both of Jrichker's lists (the no-crank checklist and the cranks but no-start checklist). Otherwise, we will be throwing out thousands of random ideas. WIth the lists, you can systematically test and confirm that everything is ready to go (you will have cranking issues and then no-start issues, I'm sure).
Good luck.
88mouse
630
Mooresville nc
Feb 13, 2009
  • Feb 13, 2009
Can you take a pic of the starter relay?
stangbang302
180
fort valley, ga
Feb 14, 2009
  • Feb 14, 2009
well did some researched about a starter relay diagram saw a pretty simple one and looked under my car and realized i didnt have that little spade wire hooked up to the starter. maybe thats the problem?
HISSIN50
34
129
Feb 14, 2009
#10
  • Feb 14, 2009
  • #10
That little spade not being connected will not keep you from having lights or anything other than a car that won't crank.
If you have no lights (as noted in post one), you have another issue going on as well.
Good luck.
stangbang302
180
fort valley, ga
Feb 14, 2009
#11
  • Feb 14, 2009
  • #11
well i got all the lights working now. dash lights headlight etc.. car just wont even try to start up
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
