  • SN95 4.6L Mustang Tech
I need some help
  • Thread starter Thread starter 04GTMustang
  • Start date Start date Oct 4, 2006
04GTMustang
348
Stafford
Oct 4, 2006
  • Oct 4, 2006
Alright well my car is having a bit of problems I get a pop/rattling sound in the exhaust when i put the car under load and it sounds like its coming from the manifold area. It gets louder the harder i push down the pedal
i took some readings with my diablo predator and my long term fuel trims are
+7 on bank 1 and +9 on bank 2
My baro is 30.5hz
I have no idea what the heck is the problem with the car is has absolutely 0 low end power heck even top end power seems to be down. Basically a 99 gt with catback exhaust pulled on me easy. Oh and im also running 94 octane gas so i dunno if its ping or not and im back on the stock tune and it still does it.
I have no clue what the problem is with the car so anything would help and i have no money for a new motor either so if she blows then im sol. oh and i pulled the plugs and they seem to be a little white on bank 2 but not bad at all bank 1 looked fine.
TweekedGT
1,274
Alberta
Oct 4, 2006
  • Oct 4, 2006
Are you getting unburned fuel in the exhaust? It will make popping noises. You may be running too rich, bad injector?
Superhereaux
chicks make me feel inadequate
538
South Texas
Oct 4, 2006
  • Oct 4, 2006
how is it running at idle?
the +'s are your car adding fuel because it's running lean, the car is trying to compensate. the +9, +7
noramally i'd say you have a vacuum leak somewhere but the "pop/rattling noise" seems to point elsewhere, like an exhaust leak maybe
does the noise seem to go away when the car is warmed up?
04GTMustang
348
Stafford
Oct 4, 2006
  • Oct 4, 2006
no the car does it just as much when its warm if not more and it idles perfectly fine too no surging what so ever.
04GTMustang
348
Stafford
Oct 5, 2006
  • Oct 5, 2006
any other suggestions?? Im gonna ask the ford tech guys on tuesday cause i have an appointment set up to get my gears installed then. But this is really making me mad its not as quick as it once was I have no low end power and it takes for ever to wind gears out. Like 2nd gear feels like an eternity trying to rev it all the way out to 5500.
oh and would an exhaust leak cause the low baro reading because pretty much all of these problems started to occur when i put the xpipe on. we had the exhaust welded and it was fine for a while and then the noise came back i tightened everything about about a week or two ago and it still made teh noise so do you think a bad gasket could cause those low readings like that? And i dont have a check engine light either
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
