So I am new to the forums and I really need some help. I own an ac cobra replica that has the efi wireing harness from the 90's I believe? The unit is from www.mass-floefi.com it uses a A9L ecu.
The issue started when I was driving down the road and the car completely died.
When I turn the key to the on position. The check engine light comes on, the relays click, and the fuel pump primes, all for only like a split second. Way less than normal. Then everything is dead again.
When I check voltages I see 12 volts coming in every where I checked except for the inertia switch. I am not seeing the voltage I should be seeing there. I have replaced all the relays as well as the inertia switch.
I am out of ideas here.. Could it be a bad ecu?
Dan
Dan
