Ok my car has 172,000 miles on it and runs alright besides leaking oil from the rear main seal. I figured its time for a rebuild and I might as well stroke it while its out.I want a 347 that will make good NA power, I might decide to spray a small shot on it later but for now I'd just like a stout NA motor that will be a daily driver. I'd like to stay with stock compression ratio or maybe even higher, I already run 93 octane. The heads I think I want to go with are AFR 185s unless someone thinks another head would be better suited. As far as intake manifolds I am open to suggestions, what intake manifold would work the best?
Also my best friend is a car tech that graduated about 6 months ago from school and he said he'd help me build it he is very knowledgeable I learned most of what I know about cars from him before he even went to school. Should I buy a pre-assembled short block like from DSS or CHP, or do you think we should do it ourselves? What would be the best stroker kit for these goals? What will I need to keep the stock compression or higher with aluminum heads? Thanks beforehand for any help.
