IAC Spacer kit?
  • Thread starter Thread starter Jrock909
  • Start date Start date May 1, 2007
J
Jrock909
36
  • May 1, 2007
IAC spacer, do these really work for a surging idle when a 302 engine is warmed up?
HISSIN50
34
129
May 1, 2007
  • May 1, 2007
It's totally hit or miss. That's why there are (or used to be) a lot of those floating around in the classifieds.
Good luck.
J
Jrock909
36
  • May 1, 2007
Yah I was basically trying to get a show of hands to see if this kit really worked on stabilizing idle, I mean apparently it does something if Ford made the darn things!
HISSIN50
34
129
May 1, 2007
  • May 1, 2007
Good luck.
TheBocSez
652
Converse, TX
May 1, 2007
  • May 1, 2007
Had one, didnt do anything for me.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 1, 2007
  • May 1, 2007
You guys with idle problems could same a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :
AnthonyR23
661
Ontario
May 2, 2007
  • May 2, 2007
Another way of saying what Jricker is trying to is that there is underlying reasons why your having idle problems.. and the spacer is like a quick fix.. but doesn't actually fix what is wrong..... technically...
AnthonyR23
661
Ontario
May 2, 2007
  • May 2, 2007
don't worry everyone who posts with idle problem's are just chasing their tails..
daddystang
185
  • May 2, 2007
Go through the checklist that jrichker has compiled. One quick, free thing you could try is to flip the IAC upside down. I did it, and it helped quite a bit. I also have the IAC adjustment plate installed, and it doesn't seem to do anything.
Hope that helps.... Good luck to you.
Let us know how it goes.
T
TheUser
1,859
Springfield, MO
May 2, 2007
#10
  • May 2, 2007
  • #10
If the IAC is aftermarket (I believe "Wells" brand), it needs to be flipped upside down, as mentioned, for it to work correctly.
I *DID* get the Ford IAC plate and it seemed to work (at least make a very noticeable difference) on my GT. My LX also has it from a recall. The reason Ford made them - as I understand it - is that they had problems with the IAC's getting junk in them and having to be cleaned by the Techs. It was more cost efficient for Ford (with the vehicle under warrenty) to just design and produce the IAC plate and have the Tech's install it than to clean the IAC out.
When I called the local ford dealers, they told me they didn't make such a thing, so you may want to locate the product number and call around using the part number instead of trying to explain it. If they tell you there is no such thing, they're full of s hit.
udogtexas87gt
#11
  • Oct 22, 2010
  • #11
Also flipped aftermarket IAC and fixed my surge
I replaced IAC right away when I had surge; with an Autozone/Duralast/Wells unit. Installed as the old one was(rightsideup) It did not fix surge; replaced & rerouted vacuum hoses, replaced fuel pump & filter, adjusted tps, new ignition switch, new speedo cable and vss .....and still no fix. I had read about flipping the IAC but put off as a last ditch effort and after fixing all the other things, I read about it again and it was mentioned that if it was an aftermarket/Wells unit that u had to flip it for it to work...........soooo guess what?! Just make sure u reset/disconnect ur battery for 10-20 min to clear computer after u've flipped it. Keep checking those boards!
H
Haus
408
#12
  • Oct 22, 2010
  • #12
wow old thread haha
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
