Ideas on this one...
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Mar 22, 2004
Black Sun 5.0
1,337
L.I., N.Y.
Mar 22, 2004
  • Mar 22, 2004
My car is too odd. I've had bad gas mileage (by my standards), and have had a few posts on this issue. It's gotten weirder. My car had gone from 27 MPG highway down to 14 MPG, regardless of where or how I drove. Thing was running real rich. I also had an issue with fluctuating readings on my volt gauge, it would dip kind of low for the most part, even though there was a new battery and alt. I messed around with some of the wiring, including by the battery and the starter solenoid. The volt gauge was up more consitently, and my gas mileage bumped up to 17 MPG, a little lower if I stomped now, but the way it should probably run. I brought the car to the shop, had the ECT, the t-stat (went back to stock), and the O2's replaced. We also discovered that a bad ground was causing the volt fluctuations. Now I'm back down to 14 MPG and running rich again. What the heck is up with this thing?
M
mike93lx
391
Hudson, MA
Mar 22, 2004
  • Mar 22, 2004
you mentioned twice that its running rich, but you haven't said anything about trying to adjust the fuel pressure. i would definitely get an adjustable pressure regulator and a pressure gauge and lower the fuel pressure. it seems like your current regulator isn't working
Black Sun 5.0
1,337
L.I., N.Y.
Mar 22, 2004
  • Mar 22, 2004
I had an adjustable FPR installed and adjusted not too long ago in response to this issue. It didn't help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 22, 2004
  • Mar 22, 2004
Codes? Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
Post the results and let us know what you get.
Black Sun 5.0
1,337
L.I., N.Y.
Mar 23, 2004
  • Mar 23, 2004
No codes, except for the vapor cannister, but I never had that hooked up.
sleeper89
388
Toronto, Ontario
Mar 23, 2004
  • Mar 23, 2004
when did the problem first occur?
have you had idle issues?
have you tried "clocking" your c&l?
i'm trying to isolate the issue so any info is helpful.
-steve
Black Sun 5.0
1,337
L.I., N.Y.
Mar 23, 2004
  • Mar 23, 2004
There's another thread with a similar issue that I jumped into. The car runs excellent. It used to have a real bad surge problem, but has since gone away. Every now and then you hear a bit of a 'wave' sound in the idle, almost like a mini-surge, but nothing that only the owner would notice. The issue started around the time I had my heads put in the car, but may have started before. The decline in mileage was gradual, not an overnight thing. The other post I'm in someone mentioned injectors being stuck open. Possibilty? I think it's the only thing I have not yet replaced.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
