  • 1994 - 1995 Specific Tech
Idle issues with the 351....
  • Thread starter Thread starter nmcgrawj
  • Start date Start date Aug 15, 2005
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Aug 15, 2005
  • Aug 15, 2005
Well it doesnt happen all the time. I would say 60% of the time it idles fine. Starts up and idles great. But other times while driving it will cut off as im coming to a stop. Then when i go to start it back up it will not idle at all. Just cut right back off unless i keep it alive. And if i go somewhere, park, turn it off and come back out, sometimes it will do the same thing. And when i try to take off it bucks like crazy...then BAM it runs fine...idles fine... Its very annoying.
Anyone ever have issues like this? I tried cleaning the IAC. By the way, its a fox TB setup. It idles around 800 rpms when running the right way.
Mike(grn92lx) told me to try messing with the start up fuel tables in my PMS which i plan on doing, just wanted to see if anyone else had any tips.
bjl95mustang
1,495
Austin,TX
Aug 15, 2005
  • Aug 15, 2005
Could it be a bad connection somewhere in the comp or maf? play with all of wires while it is running and see what happens.
gcomfx.com
3,690
Republic, MO
Aug 15, 2005
  • Aug 15, 2005
Something simple and cheap to try:
Try spraying a mist of water around the intake area while the engine is running to see if you have a vaccum or intake leak. If it makes it die or changes the idle, you found your problem... if not, you washed you engine.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Aug 15, 2005
  • Aug 15, 2005
I will try those out but i think its something more. Could the IAC be bad already? I just got it this year and it has 2 months top of driving on it.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
