Idle problem for 4 years!! HELP!!!
  • Thread starter Thread starter emagdnim
  • Start date Start date Apr 25, 2005
E
emagdnim
391
15
28
Apr 25, 2005
  • Apr 25, 2005
Hello , My car is a 1988 speed density..
My car is running great now after tuning it up just it idles @ 1400 rpm without the IAC connected... With that connected it even idles higher when it opens up. Ive checked the hoses for vacc leaks but they all seem ok.. Ive replaced the tps sensor (set it to 0.99v) , Replaced the EGR (old one was plugged up..) , replaced the pcv valve but it still idles like a crazy mofo... Ive taken off my long tube headers and xpipe and put everything back to stock because i plan on doing a h/c/i swap this summer but i want the car running perfect before i start doing that to avoid future problems. Could something like a Temp sensor cause the fast idle or does it basically come down to some kinda vacc leak that im overlooking? Ive sprayed carb cleaner around the hoses and it didnt make a difference and ive listened closely for leaks . Any suggestions this is something i cant seem to fix.
HISSIN50
34
129
Apr 25, 2005
  • Apr 25, 2005
what is the vac reading at idle? it should be real close to 20" hg at idle (for me, 700 rpm). any codes?
has the idle been set or messed with recently? here is a decent write up on setting the idle:
http://www.muscularmustangs.com/iac.php
the car should idle (warm motor, no load) on its own without the IAC, and it should be near 700 rpm if you have a stock cam.
good luck.
E
emagdnim
391
15
28
Apr 25, 2005
  • Apr 25, 2005
I tested at 18 lbs of vacc at idle which is around 13 - 1500 rpm , ill read that article thanks.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
