Idle problem, what could it be?
  • Thread starter Thread starter 1990LXDropTop
  • Start date Start date Jul 19, 2005
1990LXDropTop
430
Western Massachusetts
Jul 19, 2005
  • Jul 19, 2005
My car has been idleing fine since my h/i/c swap for months now; that is until now. Most of the time now it usually idles fine, but every now and then it will start idleing at 1500rpms+++ and won't go down unless I shut the car off and re-start it. Could this just be a bad IAC sensor? What else could it be?
1990LXDropTop
430
Jul 19, 2005
  • Jul 19, 2005
ttt
J
jimilane
158
Raleigh, N.C.
Jul 19, 2005
  • Jul 19, 2005
Well, they say it's usually the Throttle Position Sensor. I know that they will check fine, and can be set fine, but still have a problem.
Also, if you have messed with the adjustment screw for the throttle, it will also tend to hold or raise the RPM during shifts.
Most everyone sets the gap on the throttle adjustment screw to throttle blade plate to .010 then turn the screw and aditional 1.5 turns. Also some set it to .002, then turn a half a turn. You just need to make sure it doesn't bind.
Jim
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jul 19, 2005
  • Jul 19, 2005
I found a sneeky vac leak after my 200th inspection of vac lines..also check the hego ground for the o2 sensors, and check the PCV grommet for any sign of slack fit. Clean the standard parts like TB and IAC, along with MAF and reset the TPS
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
