idle problem
  • Thread starter Thread starter mondotron
  • Start date Start date Jan 31, 2011
M
mondotron
  • Jan 31, 2011
hi i have a stock 87 mustang gt and it idles a little high. also when i shift into gear and press the clutch the engine revs a little bit too
i have know idea what it is can anybody help?
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 31, 2011
  • Jan 31, 2011
the revving when shifting makes me think IAC is gummed up...
M
mondotron
  • Jan 31, 2011
yeah i sounds about right and thats going to be the first thing ill check but also someone checked out my car and said air is being sucked in through the back of the intake manifold
M
mondotron
  • Jan 31, 2011
yeah it sounds about right and also some checked my car out and said air is being sucked into the back of my intake manifold
Mintsick
589
39
68
West Lafayette, IN
Feb 1, 2011
  • Feb 1, 2011
Through the smog ports in the heads or the actual intake manifold?
fiveohwblow
Official Member
2,169
145
155
Feb 1, 2011
  • Feb 1, 2011
That could be your pcv valve. They pop out or wear out on occasion.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Feb 1, 2011
  • Feb 1, 2011
I'd run your check engine codes. This could be many things.
Of course if vac lines are missing or open, at would be an issue as well
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 1, 2011
  • Feb 1, 2011
See the "Surging Idle Checklist for help with all your idle/stall problems.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes] for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
M
Idle control valve
  • miser143
  • Oct 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2026
General karthief
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
