  • SN95 4.6L Mustang Tech
Idle Problem?
  • Thread starter Thread starter sonicstang00
  • Start date Start date Jun 28, 2011
sonicstang00
  • Jun 28, 2011
Alright guys hopefully someone can help me, Everytime i apply the clutch before i shift the car idles up to about 2-2500 rpms and sticks there, I replaced the iac already and checked my hoses and none have holes in them thought maybe a vaccum leak, any suggestions?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 28, 2011
  • Jun 28, 2011
Check all fuses. If this is a 99-04 MY, check fuse F2.2 and F2.8.
Any mods? After market TB? Have you attempted to adjust the idle set screw? Is the throttle return spring closing the TB fully? Do the throttle linkage move smoothly and freely?
A bad TPS can cause a hanging high idle. The best way to trouble shoot is to monitor the TP-MODE PID. This will indicate if the PCM is seeing a good closed throttle TPS signal.
A vacuum leak after the TB butterflys can also cause a high idle. What about the PCV system? Remember that it's basically a controlled vacuum leak.
Please review:
Ford Mustang Forums - View Single Post - Is your mustang stumbling, dieing at idle or idling rough?
sonicstang00
  • Jun 28, 2011
Thanks! im gonna bring it in the shop and test these! I hooked it up to the scan tool tonight but nothing was out of its range so It leads me to think that the iac is sticking...second one i have put on this car.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 29, 2011
  • Jun 29, 2011
So you confirmed the TP-MODE PID?
IAC's don't normally have such a short service life. Since the IAC has been replaced twice, IMO this leads weight to it being another problem. Which if there aren't any vacuum leaks, a bad TPS is high on the list.
Good luck.
sonicstang00
  • Jun 30, 2011
Fixed it, the TB was sticking i suppose i switched it and put the stock one back on and it hasnt done it since!
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
