Hi everyone!
I have been chasing an idle problem now for quite some time. I have a 93 LX Convertible w/ a 5.0 5 spd. When I am running down the road and push in the clutch or just put the car in neutral it "idles" at 1500RPM. Then after a min. or so it will drop down to about 1200-13000 for about a min then down to about 1000 for about a min then back up to 1200 then back down then back up and so on... I know it is not my Idle control valve because I have completely blocked it off with a gasket to make sure it wasn't that. I have checked my MAF and it seems to be ok. So... I ran codes to see if anything showed up but nothing stored, however, when I ran the running test it came back with 41 (lean) and 91 (O2 sensor). Could my O2 sensors realy be causing my car to idle like this? Anyone have any other suggestions?
He will not only provide information, but usually back it up with pictures and links.
). It's further adds frustration when there's not enough info provided initially to be able to help much.
