idle ?
shttygtstang
978
ok im putting my motor back together so i decided to start it and idle jumped up to 5000 right away now i dont have my egr on the spacer or ne sensors like my iac ect hooked up nor non of my vacume lines.would this cause my idle to jump up like that or should i look else where .before i took it apart it was fine
to see if it was all going together right .......
can ya help me.i thought with the car would not idle at all but i was wrong .i dont wana put all this back together to tear it apart again
Well, not having all the sensors and vacuum lines and whatever else you don't have on is your problem. If the car was running, I don't see it having a mechanical problem. Was that what you wanted to hear?
sounds like you have the ultimate vac leak (amongst other issues with no ancillary components being hooked up). that would cause a very high idle.
good luck with getting it all together.
