  • SN95 4.6L Mustang Tech
Idle!!!
  • Thread starter Thread starter The Stang GT
  • Start date Start date Jan 2, 2006
The Stang GT
81
  • Jan 2, 2006
Why when i have my car in neutral it just shuts down, or when i put the car under heavy braking, it just shuts off, I was thinking that i adjust the idle screw and see what happens, what do u guys think??
D
Dragstr05
643
Stafford VA
Jan 2, 2006
  • Jan 2, 2006
Sounds like an IAC problem.
The Stang GT
81
  • Jan 2, 2006
Wat exactly is the IAC???
ponysarepretty
578
  • Jan 2, 2006
idle air control, its the shiny cylinder at the front of your upper plenum.
1LowGT
294
st louis mo.
Jan 2, 2006
  • Jan 2, 2006
ide air control dont adjust anything fix the problem at hand,or the tps will be reading higher at idle than it needs to be,
The Stang GT
81
  • Jan 2, 2006
What exactly is the tps???
stangGT97
1,299
Boston area, MA
Jan 2, 2006
  • Jan 2, 2006
throttle position sensor. Do a search, there are about 300,000 threads about the IAC and how to replace it
D
Dragstr05
643
Stafford VA
Jan 2, 2006
  • Jan 2, 2006
IAC = idle air control valve. It lets a certain amount of air into the engine when the throttle plate is closed. If the IAC is clogged or restricted, the engine will stall because it is being starved of air.
The TPS is the throttle position senser, located on the throttle body. When you open/close the throttle, the tps moves accordingly and sends a signal to the computer saying what the position of the throttle is. This is why you usually need to adjust the tps after installing a new throttle body.
I still believe your problem is the IAC. They arent too expensive, I believe probably 30 or 40 bucks but I'm not too sure. Replace that and it should fix your problem.
stangGT97
1,299
Boston area, MA
Jan 2, 2006
  • Jan 2, 2006
$49.99 at Autozone
IAC
Some will tell you that you should only buy an OEM IAC, but I haven't run into any problems yet with the AZ one
hotmustang331
2,967
Bastrop,TX
Jan 2, 2006
#10
  • Jan 2, 2006
  • #10
You can also remove it and clean it with break cleaner/WD40 ect. Worked when mine was starting to die for no reason coming to a stop.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
