Idler Arm Bushing
  • Thread starter Thread starter RED MUSTANG
  • Start date Start date Jul 24, 2007
R
RED MUSTANG
14
  • Jul 24, 2007
Whats the best and easiest way to remove and install an Idler Arm Bushing on a 66 stang
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jul 24, 2007
  • Jul 24, 2007
Hydrolic press.
If you don't have a press, you could always try a socket and a BFH. They can be a real pain to remove tho... you might save yourself a lot of hassle by paying a shop for 1/4hr labor.
R
RED MUSTANG
14
  • Jul 25, 2007
BottleFed70 said:
Hydrolic press.
DO I GET THE ARM OFF USING A PITMAN ARM PULLER. ITS KIND OF TIGHT TO GET THE PULLER AROUND THE TOP OF BUSHING
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 25, 2007
  • Jul 25, 2007
Lay off the CAPS man.
You could provably just use a pickle fork since you are replacing the bushings.
M
mustangman1974
463
  • Jul 25, 2007
Two connection points:
Off the center link: I have used a tie rod puller.
Off the frame: 1. Unbolt it from the frame 2. Spray it good with WD between the shaft and bushing. 3. Reinstall nut a few treads and wack it with a plastic hammer. (no not a toy but one with hard plastic to protect the nut or threads.
M
mannyjoe
  • Jul 25, 2007
I used a long 1/2" threaded rod and a few appropiate sized sockets to remove and replace the bushing after the 2 piece Idler arm was removed from the car.
A stop nut or vice grips can keep the threaded rod from spinning, an extra large socket on the bottom to catch the old bushing. A deep socket small enough to displace the bushing but not get stuck in the Idler arm is used to displace the old bushing.
Install is the opposite, using a socket just large enough to contact the flange at the top of the new bushing to press it in, pretty straight forward. HTH.
mannyjoe
R
RED MUSTANG
14
  • Jul 26, 2007
Thank you everyone. I took the idler arm off and brought it to the shop up the street. He pressed it out for me and pressed in the new bushing. He did not even charge me for it!! its back on the car and seems to be fine. thanks again
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
R
Suspension Bushings for SN95 Steering Rack with UPR K Member
  • Riley Barth
  • Jun 23, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
