idler arm
  • Thread starter Thread starter tretz
  • Start date Start date May 5, 2004
T
tretz
62
stockton, ca
May 5, 2004
  • May 5, 2004
is there anything I should know about installing a new idler arm in my 67. Iv'e replaced everything under the front end and tightened the heck out of everything else, but where the idler arm attaches to the center link I'm not sure how much to tighten here?
R
Ronstang
1,294
Houston Texas
May 5, 2004
  • May 5, 2004
It is a tapered stud so make it tight but don't gorilla it and stretch the threads...it has a cotter pin for safety so overtightening it does nothing but possibly damage the unit.
T
tretz
62
stockton, ca
May 5, 2004
  • May 5, 2004
I'm talking about the end that attaches at the center link , its a rubber bushing with a sleeve inside that slips over the stud on the end of the link, no taper
R
Ronstang
1,294
Houston Texas
May 5, 2004
  • May 5, 2004
Same thing....make it tight but not too tight to damage it. You simply want to grab the teeth on the sleeve enough to keep it from turning and then put the cotter pin in.
T
tretz
62
stockton, ca
May 6, 2004
  • May 6, 2004
that makes sense , I seem to remember somthing about having the wheels straight ahead too, does this help bring the wheels back to center after turning
R
Ronstang
1,294
Houston Texas
May 6, 2004
  • May 6, 2004
You are correct...the wheels need to be facing as straight ahead as possible or you will preload the rubber bushing and end up with erratic steering. It might aid in returning to center but your caster setting is more important.
T
tretz
62
stockton, ca
May 6, 2004
  • May 6, 2004
thanks , I hope to get this project right the first time
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 3:55 AM
manicmechanic007
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
What is it Worth?!?!? Jun 13, 2026
KRUISR
