If anyone is interested my 66 Fastback build site.
watching
I like what you are doing.
+1 for the Webers.
One suggestion. While you are working on the firewall consider what transmission you will be using and if necessary do the work on the trans. tunnel at the same time.
I sure hope you have a plan to stiffen up the front end after the Heidts install. Just covering the hole where the shock towers were is not enough. These cars need the triangulation that the braces from the shock towers to the cowl provide. Just installing a Mustang II setup in a classic as designed creates a "flexy flier" at best.
Global West Export Brace\Monet Carlo Bar
Was looking on Global West's site and saw there 4 bar export brace and straight Monte Carlo bar and wanted to know if anyone has installed either and
are you happy with it? I am currently using TCP front end suspension but do not necessarily like there export brace.
Thanks,
Rus
