ignition/fuel issues??
  • Thread starter Thread starter 89OctaneStang
  • Start date Start date Jan 10, 2009
89OctaneStang
12
Ft Lewis, WA
Jan 10, 2009
  • Jan 10, 2009
I was on my way home last night and the car was running fine. Then all the sudden it got sluggish and choked itself out while sitting at a light. After a few minutes it would fire back up and ran fine but then after a minute or so, it got sluggish again and choked out. Like it was out of fuel but it has a full tank.
I pulled into a parking lot and did a quick visual on things but everything looked normal. Went to fire it back up to see if it would run ok after sitting for about ten minutes and it ran just fine, for another few minutes then got sluggish and died again. Finally just had it towed home.
Fuel pump primes like normal and fires up first crank after sitting for a few minutes with no issues. Runs normal even with reving and all. But only last for a few minutes.
Any ideas?
One suggestion from a buddy is the TFI module. Which ones have worked best for anyone that has had this issue?
HISSIN50
34
129
Jan 11, 2009
  • Jan 11, 2009
Pull codes.
When it won't run, check for spark, injector pulsing and fuel pressure.
If everything looks ok, consider an exhaust restriction.
89OctaneStang
12
Ft Lewis, WA
Jan 11, 2009
  • Jan 11, 2009
OK. I'm confused now. I was told that when they go bad they will overheat and stop working at high or normal temps. I pulled it out of the garage and let it run for a while and got it up to the normal operating temp (which is where it was when it died on me Friday) and it ran fine the whole time. So my next test that I'm going to do will be to take it out around the neighborhood and just keep driving it till it acts that way again (if it even will). On Friday it had been running for about 1 1/2 hours before it did what it did. So after driving it around for 15 minutes or so and it doesn't do it, I will give up...
I'll keep you all posted.
89OctaneStang
12
Ft Lewis, WA
Jan 11, 2009
  • Jan 11, 2009
Well, took it out and ran it for a while. Runs like normal. Maybe this is why they say its hard to diagnose the TFI module cause after you get it to the shop it runs fine cause it isn't hot enough to kill the module.?.???
I will be putting a new one in later this week and I will just keep the old one just in case. I'll keep posting as to if the problem persists or if a new module has seemed to fix the problem. But like I said, if I were a mechanic I would be looking at me like I am an idiot cause the car runs great now...
ID89GT
1,659
18
49
Spokane Valley, WA
Jan 11, 2009
  • Jan 11, 2009
My guess is a fuel pump going out
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 11, 2009
  • Jan 11, 2009
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
HISSIN50
34
129
Jan 11, 2009
  • Jan 11, 2009
To give a relative idea, the TFI's critical temp is ~257*F. That generally takes getting on the car and/or a bit of heat-saturation per time.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
