1993 LX 5.0 dies after ignition parts replacement
Warhorse85
66
18
18
Hello everyone, I'm having trouble figuring out why my wifes 1993 LX 5.0 dies while idling after replacing some ignition parts. The parts I have replaced are the MAF, TFI module and ignition coil. EGR was replaced last year. Car starts and runs great but after idling for a bit it surges for a couple of seconds then goes back to idling normal then about 5-10 seconds later it just dies as if someone turned the ignition key off. It will instantly restart and idle with no issue for a few minutes and do the exact same thing. I did notice that there is a loud buzzing noise coming from the EGR area while it's idling. Any help would be greatly appreciated.
Basic things that you need to provide in a thread like this.
Stick or Auto?
Mods
Any codes?
What were the name brand of the parts that you used to replace the existing parts and why did you replace them?
The check engine light (CEL) only illuminates for emissions related codes. There can be codes and no CEL so if you have not scanned for codes please do so.
Stick or Auto?
Mods
Any codes?
All parts replaced were Motorcraft. Car is an automatic convertible. The specific parts were replaced because my wife was driving home from work on the expressway and the engine was surging, then backfired, then ran and shut off as if the ignition key was turned off and no restart. Got it towed home and found no spark and no ground pulse to the coil. No codes other than the ones relating to me removing the smog pump years ago and no check engine light
Man that helps a lot! I would think there would have been several codes with what you described.
My guess would be the ECU needs to be gone through. We are seeing a lot of this as these are now 30+ years old and several of the components are timing out. We are having great luck with The ECU Exchange.
Only other thing I can think it would be is the PIP but with the ECU not giving codes for the scenario you described that would just be throwing more parts at it.
I had a thought though. The EGR was making a loud buzzing noise while it was running. I was leaning towards a defensive EGR and/or IAC. When I got the car running after replacing the parts, I backed down to the end of my driveway, put in drive and slammed the throttle and it spun the tires, which it's never done before. I also did a power brake and not only did it screech the rear tires, it overpowered the brakes and pushed the car forward
Did you remove the old thermal pasted and put new thermal paste between the distributor and the TFI? We usually recommend this one:
Also, I’ve asked one of the mods to combine both your threads into one. This helps keep all the info in one thread which greatly helps trouble shoot.
I will say that having the ECU gone through is money well spent.
Reactions: Mcmahst
I actually just learned about the thermal paste, and no I did not put any on the TFI. I will go get some and redo it. The car starts and idles beautifully until it gets hot and then it just shuts off as if the ignition key was turned off. It will immediately restart with no hiccups at all
TFI may be overheating. It uses the aluminum distributor as a heat sink and if it cannot transfer the heat it will quit working.
Be sure to clean all the old stuff off. Brake cleaner on a rag does the trick. Carb cleaner will leave a residue so stick with the brake cleaner.
I've had trouble with replacement tfi modules, if the paste doesn't help try the old module ,if you still have it.
I found the paste at a computer store.
I think what he’s alluding to is even the Motorcraft ones can not be good out of the box. Seems things aren’t built like they used to be.
I have a spare Motorcraft one (new) sitting in a box. No need to replace mine but I bought one just in case.
Reactions: nickyb
I would bet they were subcontracted out to third parties even when the cars were brand new. The automakers don't make the parts in their own cars much anymore.
What I meant was the parts were made by Standard Motor Products, Magna, Linamar, etc., not at a Ford owned plant. Sure, now all those companies manufacture overseas - hence made in China.
So I added thermal paste to the new TFI and no start. I reinstalled the old TFI and it struggled to stay running and then died. I disconnected the SPOUT connector and it started and then I set the timing and it ran for about 5-10 then died as if the ignition key was turned off and no restart. With the SPOUT connector disconnected I have spark and ground pulse at the 2 wire coil plug while cranking. Fuel pump does come on and primes when key is turned on.
