Ignition Module
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Jun 11, 2004
Black Sun 5.0
1,337
L.I., N.Y.
Jun 11, 2004
  • Jun 11, 2004
I got my new ignition module and also the tool from 50resto.com to remove the screws, but there's abely NO room for the tool to get one of the screws out (the rear one). Anyone have any suggestions?
Mavrick
2,264
Collingwood, ON
Jun 11, 2004
  • Jun 11, 2004
I bought a new ignition switch too... and wondered WTF kind of screws are those. Where can i find the tool, any hardware store? How much do they run?
Black Sun 5.0
1,337
L.I., N.Y.
Jun 11, 2004
  • Jun 11, 2004
I know it's a hex screw, but good luck getting the rear one out. Like I said, 50resto sells 'the' tool, it just didn't have enough space to get to that rear screw.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 11, 2004
  • Jun 11, 2004
Take the distributor out or twist it until you can get to the screw.
Take the coil wire out of the distributor. Pull #1 plug, put your finger in the spark plug hole. Have someone crank the engine until it starts to blow air past your finger. Stop cranking, turn the engine by hand (breaker bar on the harmonic balancer bolt, or put the car in gear and push) until the TDC mark on the harmonic balancer lines up with the pointer on the passenger side of the engine. Loose the distributor hold down bolt, remove the clamp, cap and wires, disconnect the wiring harness. Pull the distributor straight up.
The following re-install depends on the engine being lined up as in the previous instructions.
To re-install, turn the distributor rotor to point to #1 cylinder position on the cap. The#1 position is about 11 o'clock if 6 o' clock is the front of the engine. Line the rotor up with it pointing at the #1 spark plug position on the cap and drop it in: you may have to twist the shaft some to get it to engage the oil pump shaft. Then remove the SPOUT connector plug, and use a timing light to set the timing. The SPOUT is the dangling connector on the distributor harness on stangs made prior to 94 and with a computer controlled engine. 10* is stock for most 5.0s' 12*-14* is good for more pep if you are not into NO2 or power adders.
somersdp
191
WPB,Florida
Jun 11, 2004
  • Jun 11, 2004
Simply mark the spot the dist. is at now at the base of it and loosen the hold down bolt (1/2"). Take off the module, be sure to clean the surface behind it and add new module compound/dielectric grease. Install the new one and return your dist. to the old setting. As long as the car is not started you wont need to re-time your car. If it was me, I would hit it with the light just for GP....Ya know!!
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 12, 2004
  • Jun 12, 2004
You can get the tools at any autoparts sotre -- they're relatively cheap. Some cars have torx bits, some are hex bolts -- the tool will have both most likely. You should be able to get to both bolts by just turning the distributor.
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
