Ignition Problems?? I think...
  • Thread starter Thread starter buz19
  • Start date Start date Jun 11, 2007
buz19
9
Ontario, Canada
Jun 11, 2007
  • Jun 11, 2007
Hi Guys. Just put my newly rebuilt 289 in my 67 complete with a new engine wiring harness,alternator,solenoid,regulator,starter and pertronix ignition. Tried turning the engine over to pumpup the oil and check its pressure and got nothing. Switched the wires on the solenoid and it turned over, only I didn't have to turn the key all the ways to start it. I only turned it to the aux, position where the key normally springs to return, and the engine started turing over. I did this several times while pumping up the oil but didn't try to start it. I noticed the ignition wires started to heat up, so I'm suspecting a dead short some where but before I start that search I was wondering if anyone had this happen to them, and what the cause might have been.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 11, 2007
  • Jun 11, 2007
Sounds like you have the I and S wires switched on the starter motor relay/solinoid. If it wasn't started when you put the key into the crank position then maybe the ignition cylinder is bad or a wire is broken somewhere along the way.
65driver289
40
Salisbury, Maryland
Jun 11, 2007
  • Jun 11, 2007
I just put a wiring harnes in my 65 and there is a pink wire that should plug into the dash and then to the ignition. my car would turn over but not start with this wire unpluged. Did you mess with the dash or ignition wiring at all? You could have a bad solinoid
buz19
9
Ontario, Canada
Jun 12, 2007
  • Jun 12, 2007
I did take the instrument panel off as I wanted to repaint the steel parts on the dash. I going to put the dash back together before I try it again. I didn't do anything with the ignition wiring. I still think I have a dead short somwhere because the ignition switch wires got hot. Thanks, I didn't see a pink wire but I'll look again.
buz19
9
Ontario, Canada
Jun 12, 2007
  • Jun 12, 2007
Thanks, too busy coaching last night to check the wiring thouroughly, but once my dash is back together that'll be my next step.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
