Ignition/Starting problem
CarFreakGT
May 26, 2003
395
11
29
Louisville, KY
This is probably a simple question, so I apologize if I sound like an idiot. Sorry that it's a long post for such a simple question. I have an 89 GT, basically stock except for the exhaust. My problem is that my battery keeps dying. Sounded pretty simple to me--is it my battery or my alternator. I took the alternator off and had it checked--alternator's good. The battery is a Die Hard, so I took it to Sears because it's still (barely) under warranty--almost 3 years old. They told me that they had to give it a full charge and then test it. Fine--they charged it and their computer said that the battery is still good. So, I put my fully-charged battery and my good alternator back in the car. Drove it for about two days and the battery is dead again. My question is this: When I called Sears about the battery and told them what had happened (after they already charged it and said that it's good), they told me that it could be the starter. But, I have never had any trouble with the car turning over or starting when I jump it. He said that it may be a bad spot on the starter and they need to test it on the car. But, I would think that it would have difficulty starting if the starter is bad.
Is this a possibility, or is he blowing sunshine so that they don't have to replace the battery? Sorry if I left out any relevant info...please let me know if I did. Any input is appreciated. Thanks
Starter Troubleshooting Checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
