ignition switch?
  • Thread starter Thread starter aaros
  • Start date Start date Oct 27, 2007
aaros
114
Oct 27, 2007
  • Oct 27, 2007
I don't know how I seem to screw up simple jobs but here it goes. I changed my fuel filter and hopped in the seat to drive it from my GF's garage to my house to wash. turned the key and heard the pump prime then when I turned it to start the battery went dead. Had a buddy come over and jump start it and got it started but he swears that he could smell hot electrical smell. The wire that goes to the top of the solenoid (the press on one) looks like it has a fresh burn in the outer jacket. The last time I drove it with the headlights on and the top/windows up every once and a while I would get a whiff of something hot. Could the ignition switch be bad and cause the battery to short?
rd
3,316
63
109
Ocean Springs MS
Oct 27, 2007
  • Oct 27, 2007
Probably not the ignition switch, but it sounds like you have a bad connection in the starter circuit or battery cables.
Check all of the battery cables, both ends, and the starter feed cable to see if they are in good shape and making good contact.
Remember that the ground connection is as important as the other end...
aaros
114
Oct 27, 2007
  • Oct 27, 2007
i was all freaked out after seeing that wire and thinking that my switch was going to burn my car up that i never thought to check the battery connections! Ill do that first thing in the morning. I already have the new switch and the old one is still stamped with the ford logo, didnt they have a TSB on that? im going to change it anyway and have a look to make sure that the wires there are not burned. Thanks rd
baldy1
124
Portsmouth Va
Oct 27, 2007
  • Oct 27, 2007
yes they did have a recall on them. If its the factory one change it anyways
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Saturday at 9:20 AM
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
