  • 1994 - 1995 Specific Tech
Ignition Wire
  • Thread starter Thread starter Synned
  • Start date Start date Jun 25, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Jun 25, 2005
  • Jun 25, 2005
Where is an ignition wire I can splice into and install a cut off switch? What is the easiest wire for this to get to? Anyone have a diagram?
HISSIN50
34
129
Jun 25, 2005
  • Jun 25, 2005
Do you definately want an ignition wire? The reason that I ask is that if the switch or wire connection fails, the car can stall in traffic. A starter kill can be safer in terms of putting one in harm's way.
Good luck.
Synned
Mar 31, 2005
991
Philly
Jun 25, 2005
  • Jun 25, 2005
Well I already put one on my fuel pump power, thing is if I turn off the car then hit the switch I can still start it, I mean it will die in about 10 seconds but still I'd rather have no power at all.
CManT1914
3,172
Killeen, Texas
Jun 25, 2005
  • Jun 25, 2005
It will still start because it's using the rest of the fuel that's already in the lines. But HISSIN is suggesting that you wire a starter cut-off switch, because if you have your fuel pump switch short out while driving somewhere, then you're screwed. Your car will still run if your starter switch shorts out, it just won't start again.
Synned
Mar 31, 2005
991
Philly
Jun 25, 2005
  • Jun 25, 2005
Yeah thats fine, but which wire is the starter wire? Do you know the colors or where i can get access to it?
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
