I'm Fujed!!trans
  • Thread starter Thread starter whtnotch
  • Start date Start date Aug 30, 2007
  • 3
First Prev 2 of 3 Next Last
W
whtnotch
123
Chicago
Aug 30, 2007
#21
  • Aug 30, 2007
  • #21
heh ya, but i think its beyond chatter and beyond not using a torque wrench i know its important,but i havent had this bad of a problem not using one before.A chatter would be great LOL,but its morso a grinding.Now you have me wondering and our right i don't want to pull it back out man.....
bill302
2,131
alabama,gadsden
Aug 30, 2007
#22
  • Aug 30, 2007
  • #22
Daggar said:
Take it back apart and look at EVERYTHING. Drop the tranny, remove the pressure plate and flywheel. Inspect the drive shaft bearings and Yoke. Ensure that the alignment pins are in the correct places. Is your flywheel new or resurfaced? It should be one of those.
Check the throwout bearing and tranny snout bearing. shake rattle and roll all attaching pieces.
lol... tranny snout bearing...ya did you install a new pilot bearing or at least inspect the old one?
W
whtnotch
123
Chicago
Aug 30, 2007
#23
  • Aug 30, 2007
  • #23
new flywhell.no drive shaft spacer DO I NEED ONE?its a sn95 D/S.all new stuff including bearing
alinment pins??? where?
W
whtnotch
123
Chicago
Aug 30, 2007
#24
  • Aug 30, 2007
  • #24
oh ya i did use the syncromesh...12$ a quart i think i got robbed on that as well
bill302
2,131
alabama,gadsden
Aug 30, 2007
#25
  • Aug 30, 2007
  • #25
i needed one (driveshaft spacer) for my setup which is the same as yours except mine is a tko500 contact d&d performance they install and sell these trannys and can tell you for sure click on link below. but i would say yes...how did you mount the tranny at the tranny mount?
http://www.ddperformance.com/
W
whtnotch
123
Chicago
Aug 30, 2007
#26
  • Aug 30, 2007
  • #26
Il deff look into that.did anyone else need a spacer??i used the adjustable x member by Ford racing bolted right up...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 31, 2007
#27
  • Aug 31, 2007
  • #27
Did you install the clutch disk so that the hub springs face the rear of the car like they are supposed to? That is one thing that will make a clutch chatter everytime.
W
whtnotch
123
Chicago
Aug 31, 2007
#28
  • Aug 31, 2007
  • #28
i believe i did it correct.does F/S on the clutch disk stand for flywheel side?
W
whtnotch
123
Chicago
Aug 31, 2007
#29
  • Aug 31, 2007
  • #29
thats some bull shi t i called D&D and they won't help me4 their like you didn't buy it from us we can't help you.i wish i could see that ***er i'd slap the piss outa him...
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 31, 2007
#30
  • Aug 31, 2007
  • #30
But you didn't buy it from them. That's like me calling HP's tech support with a question about a Dell. Sure, the basic components may be the same, but it's not their product.
W
whtnotch
123
Chicago
Aug 31, 2007
#31
  • Aug 31, 2007
  • #31
thats still wrong man...anyway i just put her up on stands in the back and there is no problem,but once on the ground and i try to take off forward or reverse there is alot of binding and shaking...thanks GT for stickin with me so long on the post
BlownFiveLiter
18
108
Chicagoland
Aug 31, 2007
#32
  • Aug 31, 2007
  • #32
Hey man, that's what I'm here for. I know it's frustrating as hell when things aren't working as planned. The offer still stands if you want me to put a fresh set of eyes on it and see if I notice anything that got missed or looks out of place?
bill302
2,131
alabama,gadsden
Aug 31, 2007
#33
  • Aug 31, 2007
  • #33
i bought mine from a different source and d&d helped me to buy the parts needed to install and informed me all needed to install. parts needed was the foxbody clutch fork,tranny mount relocator,driveshaft spacer and yolk....i bought these items from them and they talked me through install and what to look for...
i called d&d and told them what i thought about not helping you, they did say to try to get help from where you purchased tranny but if they cant get help they would be glad to help you...i told them i refer alot of people to their buisness because they helped me in my installation and i was very satisfied but if it caused problems i would stop...and they said they would help if you could not get help from where you purchased it and i told him i did not buy mine from D&D but they helped me and i did purchase parts from them...and may make a sale in your case.sorry about that bro ill think twice about refering them now.
bill302
2,131
alabama,gadsden
Aug 31, 2007
#34
  • Aug 31, 2007
  • #34
The slip-yoke must be able to stroke freely on the transmission output shaft without bottoming out while maintaining maximum spline contact. Therefore, proper driveshaft length is critical. check for bottoming out...
ninety15.0
1,336
#35
  • Aug 31, 2007
  • #35
I think you need to take it down man. The problem isnt going to fix itself.
Sicarius428
2,085
Aug 31, 2007
#36
  • Aug 31, 2007
  • #36
"wearing in" isn't a great solution. Did you index the bellhousing? I have the aluminium one which is supposidly not needed but I indexed mine anyways and it was barely in spec. You got the FMS adjustable crossmember but did you have it spot welded after you got it in? I didn't need a spacer for mine but I believe you said you have a sn95 driveshaft... I don't know the difference between the two. It might be longer than the fox driveshaft possibly. Taking it apart would be ideal and starting over... sorry to say.
Kevin
W
whtnotch
123
Chicago
Aug 31, 2007
#37
  • Aug 31, 2007
  • #37
o.k car is torn back down again(suprisingly 30mins to tear down) in hopes to fix the situation.Think I found the problem the flywheel wasn't ballanced to 50oz.I'm going to national drivtrain tomm to see what the balance is of both my old flywheel and new one and mabey even the driveshaft to be sure.I reved the car up over 3K and it vibrated/shook when it wasn't even in gear so Doug at SUTTON High Performance(their mustang is covered on the new muscle mustangs if no one noticed)told me it may be the flywheel and they might of gave me a 28.5oz balance instead of a 50oz.It looks exacly how he said the new flywheel has smaller weight.Now the question is is there certain way to put the bastard on now?does it throw off the weight?
oh ya guys I was looking at the heater core threads...11hours!! and 6hours?I just did it in an hour and a half while shootin the **** with my buddy.(very easy)(no cutting)
ya 95GT for sure if this shi t happens again I will give you a buzz don't have many close people to share tech with localy.
BlownFiveLiter
18
108
Chicagoland
Sep 1, 2007
#38
  • Sep 1, 2007
  • #38
Wow, a 28oz flywheel? I never even gave that one a single thought. If the new one doesn't solve the problem, shoot me a PM or something. I'm not looking to profit from this a bit, just figured a fresh set of eyes would help with seeing anything out of the ordinary. It's only like 25-30 minutes from here to Midway, so I could check it out no problem. I guess it's a good thing you decided to tear it back down, huh? Oh, the flywheel can only go on one way. The holes look like they're drilled evenly, but they're spaced so the bolts will only go one way.
W
whtnotch
123
Chicago
Sep 1, 2007
#39
  • Sep 1, 2007
  • #39
Ya man for sure,but today is Saturday and national drivetrain is closed!So i'm screwed again and sunday and monday.so I gada start back up on it tuesday really sucks.I wana know if the flywheel is not balanced correctly.Now what i'm not sure of is I think it bolts up any way.I thought it was automatic that didn't?I will look again for sure tho.
oh ya car show on the 15th in burbank if you didn't know.I wana get this beast goin
W
whtnotch
123
Chicago
Sep 5, 2007
#40
  • Sep 5, 2007
  • #40
bringing back up the subject.I get my flywheel tomarrow and need to know is there a certain way to install?Did a few clutches before and never had to worry about this before.I wen't to put old one back on and it went on any which way no offset pattern.
Thanks
  • 3
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
02 mustang gt crank no start
  • 2v.cjmullis
  • Jan 28, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 30, 2026
