  • SN95 4.6L Mustang Tech
im going nuts
  • Thread starter Thread starter rockyracoon
  • Start date Start date Jul 25, 2010
R
rockyracoon
874
27
49
margate NJ
Jul 25, 2010
  • Jul 25, 2010
im in the process of installing 410s and freshening up the rest of the rear.
my problem is I am missing 2 C clips,ive looked everywhere,been through the trash can with a fine tooth comb,there just nowhere in sight,its like they just walked away,soI guess the stealership is in order,are they gonna charge some crazy amount like $15 bux a piece or something ?
anyone in the south jersey area have a couple laying around ?
Maxpowers
859
Pittsburgh, Pa
Jul 25, 2010
  • Jul 25, 2010
You are probably screwed my friend. I believe that's a dealer only part.
May be able to find something on the interwebs...
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 25, 2010
  • Jul 25, 2010
Look in the bottom of your pumpkin
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 25, 2010
  • Jul 25, 2010
The clips come in packs of 4 so if for some reason your dealer does not stock them, you are getting 4. They aren't too expensive from what i remember.
R
rockyracoon
874
27
49
margate NJ
Jul 25, 2010
  • Jul 25, 2010
its not really the money,but more of the time lost,because im pretty sure the dealer will have to order them.
COramprat,thats one of the first places I thought to look,but thanks for the tip.
I have a big plastic planter full of nuts,bolts and such,I guess ill dump it out and look in there, maybe theres a couple in there from bygone days,but I dont hold out much hope.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 25, 2010
  • Jul 25, 2010
OBTW, how did you remove the c-clips? Pull them out with a magent? Poke them out with a screw-driver? How did you catch the old gear oil? Did you look there?
The c-clips had to be removed before the half shafts were taken out. What did you do right before/after the half shafts were removed?
Might try a local salvage yard. The same c-clips are used across the Ford line. The salvage yard will not sell parts from a good rear end. So the challenge is to find a broken one.
R
rockyracoon
874
27
49
margate NJ
Jul 26, 2010
  • Jul 26, 2010
I used needle nose pliers to pull em out,and I remember putting them in the differential cover.
my local dealer can have em by tomorrow, $9.70 a piece.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 26, 2010
  • Jul 26, 2010
they must be made of gold!
Maxpowers
859
Pittsburgh, Pa
Jul 26, 2010
  • Jul 26, 2010
The least they can do for ya is give you a bottle of lube.
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
The Night of the Hurricane (a really long stupid story)
  • CarMichael Angelo
  • Jun 26, 2011
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2011
VibrantRedGT
