  • SN95 4.6L Mustang Tech
Im losing coolant
  • Thread starter Thread starter Bundmar
  • Start date Start date Apr 22, 2005
Bundmar
377
Ontario, Canada
Apr 22, 2005
  • Apr 22, 2005
Ive been losing alot of coolant and dont know where its going. I dont have an external leak and I dont think the head gaskests gone. what could it be?
I checked the oil and its fine
silver87
115
Northern California
Apr 22, 2005
  • Apr 22, 2005
get it pressure tested. It could be from the water pump. Check the connection where the hoses fit onto the heater core tubes. It could be a blown headgasket where the water jackets are, thus no evidence in oil and no smoke out the exhaust. How much coolant are you losing?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 23, 2005
  • Apr 23, 2005
presuure test it and you will find that it's leaking from the front of the intake manifold behind the alternator(you need a intake if this is it)... i hope you read this before you blow your car up...
Bundmar
377
Ontario, Canada
Apr 24, 2005
  • Apr 24, 2005
Im losing about a 1L a week its bad, I dont see any white smoke from the exhaust and I cant smell it. I got a KB kit going on soon but want to get this fixed first. I ll get it pressure tested and hopefully its not the head gasket.
snGTstang
58
maryland
Apr 24, 2005
  • Apr 24, 2005
probably the intake manifold is cracked. do you notice a funny smell sometimes when driving? if you have access to a beater car until your kb gets on i'd do that otherwise its about $600-$700 to get a new intake manifold.
Mike97gt
it doe snot
10,633
Apr 24, 2005
  • Apr 24, 2005
it's 90 percent most likely comming from the intake... right behind the alternator you will see it's cracked...
Bundmar
377
Ontario, Canada
Apr 26, 2005
  • Apr 26, 2005
I started it up today and noticed now there is white smoke coming from the exhaust, Its going in the shop tonight for pressure test.
Ill let u know
Mike97gt
it doe snot
10,633
Apr 26, 2005
  • Apr 26, 2005
Ill let u know
that don't sound good. sounds like it's too late
Bundmar
377
Ontario, Canada
Apr 27, 2005
  • Apr 27, 2005
too late for what? cracked intake?
so I guess the KB will be going on sooner
Mike97gt
it doe snot
10,633
Apr 27, 2005
#10
  • Apr 27, 2005
  • #10
white smoke out of the tails. sounds like you overheated it too me and blew the head gaskets.
the intake was cracked thats what caused the leak.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
A
Overheating!
  • ashleyg
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
limp
