  • 1994 - 1995 Specific Tech
****ING PIST TO THE MAX!!!!!!
  • Thread starter Thread starter Musty5.0
  • Start date Start date May 14, 2009
M
Musty5.0
26
Ontario, Canada
May 14, 2009
  • May 14, 2009
i got a 95 mustang gt bought it last year all ive done i fixed it did starter fuel pump fuel filter plugs wires cap rotor balljoints powersteering pump altenator oil pan not to mention all the labour cost cause i ain't that great of a mechanic now its running good so i decide to do upgrades so i did trick flow intake and cold air the underdrive pulleys so now i wana do rear gears yesterday i put them on found out the rear end was fuct the clutch pak was chewed out of it so i ordered a new clutch pack then the pick up coil was bad kept causeing nostarts so today got a pip but when they took the distributer out they found out the shaft at the bottom was craked so i would need a whole new distributer so i buy msd well today i get that put on with my buddy who is a mecahnic but when we took the distrubter off again the shaft was jammed on the oilpump shaft so did a little pulling to get it to break free get the msd on start the car and now the oil pump is not working I'm so pist right now i wanna just burn the car why would the oil pump not be working please tell me its a easy fix!!??
RIO5.0
6,892
N.H.
May 14, 2009
  • May 14, 2009
Take a light and look down the dizzy hole...is the shaft there?? its held in place by a clip of sorts and may have fallen into the oilpan..
The shaft from the dizzy drives the oilpump...
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
May 14, 2009
  • May 14, 2009
That really sucks. If you can still see the oil pump shaft through the dizzy hole, it is possible to line it back up again into the oil pump. But if you can't, you'll have to pull the engine to put it back in. No way around it that I can see.
M
Musty5.0
26
Ontario, Canada
May 14, 2009
  • May 14, 2009
Pulled distributer shaft out and the oil pump shaft is gone so its in the pan please please tell me theres a easy way to get it back with out taking down the oil pan.I just did the pan in it and it cost me 6 hour shop time!!!
ProKiller
3,064
15
78
PA
May 15, 2009
  • May 15, 2009
i don't know of any other way than pulling the engine out or dropping the k-member to get in there. sorry man that sucks for sure.
Suspect
256
GA.
May 15, 2009
  • May 15, 2009
pull the motor or...
pull the wp, balancer, and timing cover off. now you can see straight into the pan. if your lucky it should be sitting some where around there. get one of those flexy spider hands or magnets from the parts store and grab it out. or you can stick it back in, but some one will have to help from top guide it to the dist. hole. person on the bottom has to get it in the pump.
just remember the clip is moved now so any time you pull the dist it might fall back in again.
M
Musty5.0
26
Ontario, Canada
May 15, 2009
  • May 15, 2009
now i started the car up after instaling the dist cause i didn't know but i seen there was no oil pressure so i hope that didn't do any engine damage i shut it off fast??
Suspect
256
GA.
May 15, 2009
  • May 15, 2009
yea i mos def would not start it.
maypo59
194
Central Kentucky
May 15, 2009
  • May 15, 2009
You can just put in a new shaft, leaving the old one in the oil pan. I have a brother who has had a "spare" one in his pan for years.
GTA_V6_Mustang
1,326
Miami, FL
May 15, 2009
#10
  • May 15, 2009
  • #10
Lol I was going to suggest that too. But if you have to drop the pan you dont need to remove the engine or K-member, lol. I was able to do it no problem but just jacking up the motor all the way and removing the rack.
M
Musty5.0
26
Ontario, Canada
May 16, 2009
#11
  • May 16, 2009
  • #11
well i got the shaft out but its shaped like a j know it must of bent it when i started it that would explain the ticking i hope it didn't do any engine damage?? i ran it for like 30 seconds before i noticed the oil pressure wasn't there.
The O.G.
145
witch city,mass
May 17, 2009
#12
  • May 17, 2009
  • #12
If only your car ran as much as your sentences.
M
Musty5.0
26
Ontario, Canada
May 18, 2009
#13
  • May 18, 2009
  • #13
thats right if only....
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Fixing the Leaking 302 and doing a camshaft upgrade!
  • TTSaleen
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 26, 2025
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
