injector size
jhysock
is there anyway to tell what size injectors are in a vehicle??? 89 stang with no real crazy mods just cold air intake, svo alum heads, f303 cam (i think) msd igniton, full exhaust underdrive pully's. plugs are pure white and have tried everything vac lines, maf,computer, increased fuel psi, car is not spittn any koeo or koer codes anymore i would like to get bigger injectors if it would help in performance and fix this problem but i'm not to familiar w/fi vehicles:hail2:
Orange injectors (stock) = 19lb/hr
Blue injectors (the ones you need) = 24lb/hr
Red injectors = 30lb/hr
Whenever you upgrade injectors, you also need to have the MAF recalibrated with a new transfer curve for the new injectors (or buy an aftermarket MAF with the calibration already built in).
i've read that 24 lbs injectors will work ok with the stock maf anything bigger and u need to upgrade ur maf also will a custom chip like sct 5 bank help with my lean problem? :shrug:
Mass air meter and injectors must match, regardless of size.
A chip will just be like throwing money away.
Nothing you have there is extreme and needs a chip.
Never use a chip to cure a problem, it's just a bandaid.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
