Is it possible to test an injector? I have narrowed my search for a demon in the fuel system to a bad injector on the passenger side, staying open and dumping fuel into the cylinder while the fuel pump keeps priming. I also found fuel in the oil, and another thing that points to this is it runs REAL rich once the car decides to stop priming, then when it starts and smokes, black smoke quite heavily, I think burning off the fuel in the cylinder, cuz as soon as it stops smoking, I have no surge. and it runs perfect.
To the question, is there a way I can test the injectors, the upper intake and and fuel rail is off, I just can't determine which one is bad. All the caps are okay.
And while the pump is priming, it sounds like a hiss is coming from the injectors, hence the not closing injector.
