Injector ?
  • Thread starter Thread starter chizler
  • Start date Start date Oct 23, 2015
C
chizler
56
30
28
Knoxville Tn.
Oct 23, 2015
  • Oct 23, 2015
i found a great deal on a set of 24# inj, but they came off of a 99 gt, before i buy them just wanted to make sure they will work on my 92 lx.
stykthyn
5,232
2,652
223
gainesville
Oct 23, 2015
  • Oct 23, 2015
I believe the connectors are different. They make an adapter but I dont think it's worth it.
C
chizler
56
30
28
Knoxville Tn.
Oct 23, 2015
  • Oct 23, 2015
ok thanks for the heads up
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 23, 2015
  • Oct 23, 2015
you can get a set of blue tops for $50 all day on the corral or CL. Beware in buying used injectors unless you know the person. Expect to have them flow tested which is about another $100-$150
C
chizler
56
30
28
Knoxville Tn.
Oct 23, 2015
  • Oct 23, 2015
yeah they were on CL, i was just trying to round up some stuff for my HCI and seen these local for cheap. im going to pass on them and probably just get new ones.
stykthyn
5,232
2,652
223
gainesville
Oct 23, 2015
  • Oct 23, 2015
What's your combo?
C
chizler
56
30
28
Knoxville Tn.
Oct 23, 2015
  • Oct 23, 2015
bone stock at the moment, mostly suspension stuff, 5 lug conversion 3:73 gear. i think i have decided on the trick flow top end kit, not looking to build a drag car or show queen just want a fun car to drive on the street.
ill try to post a pic.
C
chizler
56
30
28
Knoxville Tn.
Oct 23, 2015
  • Oct 23, 2015
stykthyn
5,232
2,652
223
gainesville
Oct 23, 2015
  • Oct 23, 2015
24s would be ideal for that setup but 19s will get you up and running.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 23, 2015
#10
  • Oct 23, 2015
  • #10
Fuel injector sizing & injector photos
Revised 26-Dec-2014 to add statement about figures are for flywheel HP and not rear wheel HP
Injector HP ratings: this flywheel HP, not rear wheel HP.
Divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines at the flywheel.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
36/.5 = 72, 72 x 8 = 576 HP
42/.5 = 84, 84 x 8 = 672 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
19/.5 = 38, 38 x 8 = 304 HP x .85 = 258 HP
24/.5 = 48, 48 x 8 = 384 HP x .85 = 326 HP
30/.5 = 60, 60 x 8 = 480 HP x .85 = 408 HP
36/.5 = 72, 72 x 8 = 576 HP x .85 = 490 HP
42/.5 = 84, 84 x 8 = 672 HP x .85 = 571 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See Stan Weiss' - Automotive Performance Software / Interactive JavaScript to Calculate Change in Fuel Injector Flow from change in Fuel Pressure to get the calculators used in these examples.
Here's the duty cycle explanation. Duty cycle is how much of the time the intake is open the injectors are turned on. The 85% figure means that for 85% of the time the intake valve is open, the injectors are spraying. The idea is that you want some percentage of the duty cycle left over so that you have some room to grow the process.
If you are at 100% and you need more fuel, all you can do is turn up the fuel pressure. That means the whole fuel curve from idle to WOT is affected. Maybe you are already too rich at idle, and turning up the fuel pressure makes it worse. If you had some injector duty cycle left to play with, a custom tune could use that where it is needed. That would not over richen the whole range from idle to WOT.
If you did turn up the fuel pressure, you might be able to change the injector duty cycle to get the air/fuel mixture ratio you want since the injectors will have extra fuel delivery capability.
With larger than stock injectors or higher that stock fuel pressure, you will need an aftermarket MAF that matches the injector size. The MAF “lies” to the computer to get a fuel delivery schedule that meets the engine’s needs and isn’t too rich or too lean. The best strategy is an aftermarket MAF and a custom tune to insure the best air/fuel ratio over all the RPM range.
Don't forget to increase the fuel pump size when you increase injector size or significantly increase the fuel pressure
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
