injectors/computer for 351w
  • Thread starter Thread starter blue87lx
  • Start date Start date Dec 20, 2005
blue87lx
175
  • Dec 20, 2005
im swapping in a 351 w victor jr heads and intake.. what size injectors should i use and fuel pump? will also have a zex 125 shot. will the factory computer work with the 351?
Numbles
998
Chicago, IL
Dec 20, 2005
  • Dec 20, 2005
Stock computer will work. Upgrade the pump in the tank to a 255lph. And add an external pump if needed.
Get a tune when as well.
Daniel50
716
Discovery Bay, CA
Dec 20, 2005
  • Dec 20, 2005
30 or even 36lb injecotrs would do
O
outback
10
Missouri
Dec 20, 2005
  • Dec 20, 2005
I have a question also about this subject. A friend of mine is replacing his 5.0 with a 351w.
Can you use the stock 5.0 computer and injectors on a stock non-HO 351w?
Is the firing order etc. the same, meaning can I take the distributor out of the 5.0 and put it it directly in the 351?
Thanks...Brad
Numbles
998
Chicago, IL
Dec 20, 2005
  • Dec 20, 2005
No you have to use a 351w distributor
O
outback
10
Missouri
Dec 20, 2005
  • Dec 20, 2005
Everything else will work, or would injectors be the only other thing that needed changed?
Knowing the lower intake will have to be changed.
I'm asking on the fuel/intake system only, we know the other stuff that needs changed, just not sure about the fuel system.
N
niklid05
140
Kutztown PA 19530
Mar 30, 2006
  • Mar 30, 2006
TTT. I know this is kinda old but I would like to know the same info with a speed density and 19 pound injectors. Im sure it will go TTB but it worth a try.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 30, 2006
  • Mar 30, 2006
blue87lx:
EFI 351 W swap:
You need 351 EFI distributor,
minimum of 24 LB injectors.
MAF calibrated for injectors,
351 W EFI lower manifold.
Minimum of 155 LPH fuel pump (use a 255 LPH if NO2 or forced induction is in the future).
Stock computer: the 351 W and HO 5.0 use the same firing order. The stock A9L or A9P will work fine.
Send me your email address & I will send you the 351W swap sticky that was posted here several months ago.
NIKLID05:
Don't try and use a Speed Density computer or 19 LB injectors on a 351W. The results will not be satisfactory.
N
niklid05
140
Kutztown PA 19530
Mar 30, 2006
  • Mar 30, 2006
jrichker said:
blue87lx:
EFI 351 W swap:
NIKLID05:
alright thats what I wanted to know. Ill start looking for a maf conversion. thank you again, Jrichker!
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
