Injectors LEAK! HELP!!
  • Thread starter Thread starter PhLoBuS
  • Start date Start date May 9, 2005
PhLoBuS
473
Beverly, MA
May 9, 2005
  • May 9, 2005
Well, I am getting quite annoyed by the injectors leaking so much fuel. I simply put in a new trickflow upper/lower intake and they leak? Why? Its only two of them 2nd to last and the last one, one on each side. I have used a mallet and hit them down and still, the fuel just flows right out. I changed orings and everything on all injectors. I just want to get the DAMN car running, its been weeks and I NEED this car running. I dont have the money to replace all the injectors. It should not be them either because everything is still stock and worked fine before.
Please help me out!!
neikoblu
63
Barksdale AFB, Lousyanna
May 9, 2005
  • May 9, 2005
Just a guess, but the lower intake might be faulty. Is the fuel rail bolted down? I am sure that it is. Check the Orings for debri and small cuts or abbrassions.
PhLoBuS
473
Beverly, MA
May 9, 2005
  • May 9, 2005
it leaks where the fuel rail meets the injector, the top part of the injector
89white50
440
central MA
May 9, 2005
  • May 9, 2005
pressed down on the top of the fuel rail and tighten the bolts with pressure on them, see if that works...did for me once
BLOWN 5.0 FOX
213
NORTH SHORE MA
May 9, 2005
  • May 9, 2005
i dont reccomend hitting plastic objects with mallets,
however...you should check your stock fuel rail- be sure there arnt any o rings left behind from your last set. Just a thought. If that isnt the problem- be sure not to tweak the other of the two bolts on the fuel rail to the lower intake until both sides are evenly seated. Use a buddy to help you out if you need to. Good luck!
TomCat
412
Utah
May 9, 2005
  • May 9, 2005
Also, I like to grease the orings up a bit before installing them. I've ruined a set before by just installing them dry... microtears I guess.
PhLoBuS
473
Beverly, MA
May 10, 2005
  • May 10, 2005
Yeah I did lubricate them, I will take them off and make sure they are clean and try everything again
T
tony91723
71
  • May 10, 2005
you probably made things worst by smacking the injector rail with a mallet. But they were leaking prior to the smacking. I would suggest cleaning the fuel rails "female" portion where the male end of the injector slides into. Maybe theres dirt clogged in there.
neikoblu
63
May 10, 2005
  • May 10, 2005
Hell fuel rail might be ****. Get a new fuel rail if all else fails. hmmmmmm car parts!
BaXTeR3221
917
Orange County, NY
May 10, 2005
#10
  • May 10, 2005
  • #10
I used a mallet to seat my injectors. Just tapped it lightly and it made it nice and snug.
BLOWN 5.0 FOX
213
NORTH SHORE MA
May 11, 2005
#11
  • May 11, 2005
  • #11
BaXTeR3221 said:
I used a mallet to seat my injectors. Just tapped it lightly and it made it nice a snug.
*keyword(s) tapped and lightly
BLOWN 5.0 FOX
213
NORTH SHORE MA
May 11, 2005
#12
  • May 11, 2005
  • #12
PhLoBuS I had no idea you lived in bev Im the next town over- if you need any help Im usually in the Bev Area. If im not mistaken you live off of cabot my friends apt is right near you , and your the only orange GT with orange rims I have ever seen. PM if you get stuck on anything
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
