input shaft on t5
  • Thread starter Thread starter mustangman140
  • Start date Start date May 30, 2005
M
mustangman140
12
  • May 30, 2005
can someone tell me a place where i can get an input shaft for my t5 it is bent i think the hole car shakes after 55mph and any possable upgrades
88gt
794
Drillers cabin
May 30, 2005
  • May 30, 2005
Hanlon motorsports or your local transmission supply house. We have a place here called Lester's Gears...just about everything that has to do with transmissions (manual and automatic) in stock.
Loacl Ford dealer is a possibility
Good Luck,
Jim
M
mustangman140
12
  • May 30, 2005
how can i contact hanlon motersports
88gt
794
Drillers cabin
May 30, 2005
  • May 30, 2005
www.hanlonmotorsports.com
Sorry 'bout that..I knew better...
Jim
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,117
224
Massachusetts
May 30, 2005
  • May 30, 2005
WHy do you think the input shaft is to blame for the whole car shaking at 55MPH??
I've never seen a bent input shaft. I could list a bunch of other things i would suspect before an input shaft as to the cause of the vibration
M
mustangman140
12
  • May 30, 2005
sorry been away working on it for a while because after the problem started it was after a hugh burn out and something wasent right i thought it was the rear end so i replaced the pose ring and pinion iner and outer bearings so that elimitated that i took the drive shaft to a aamco they spun it and told me it was balencend and fine all moter and trans mounts are good and new bearnings in front also perfect alinment i told all that to guy at aamco and he said it a possable cause would be bent input shaft but i would love some other ideas and how to check them
thanks drew
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,117
224
Massachusetts
May 30, 2005
  • May 30, 2005
Did you check the tires??
A burnout could have damaged one of the belts which can screw up the balance of the wheel.
M
mustangman140
12
  • May 30, 2005
i need a bigger list. The tires on back and front have been replaced twice since this started. so i hope not next thing
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
F
T5 transmission questions
  • Forddestroyer96
  • Aug 27, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 27, 2025
Forddestroyer96
F
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
