  • SN95 4.6L Mustang Tech
Install Help PLEASE!!!
  • Thread starter Thread starter schaake30
  • Start date Start date May 5, 2004
schaake30
182
Edwardsville, IL
May 5, 2004
  • May 5, 2004
I just installed a BBK Off Road H Pipe. I bolted everything in, and connected the O2 sensors. When I went to start my car it sounded amazing, but when i went to shift into drive it wouldnt. For some reason it is stuck in park. I have no idea why this is. I have a 96GT Auto Trans. Is there a pipe made just for manual trans? Would that be why it doesnt work. I have to model number 1565. I was positive that was the right one. Could someone please tell me what I need to do to fix this. THANK YOU!
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
May 5, 2004
  • May 5, 2004
It sounds to me like your shifter linkage is caught by the drivers side o2 sensor. I had this problem somewhat with my long tubes. Sometimes, companies makes different ones for manuals and then ones for automatics. Can you by any chance get under the drives side of your car and look at your transmission pan and follow the linkage to see if its rubbing against an o2 sensor ?
schaake30
182
Edwardsville, IL
May 5, 2004
  • May 5, 2004
I will check that out, are there any other possible reasons why this would happen? I double checked and this mid pipe works for both manual and automatic.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 5, 2004
  • May 5, 2004
No, thats the only reason I can think of.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 5, 2004
  • May 5, 2004
I'm with you DK...I bet the shifter linkage is blocked. Does the shifter move at all? If it does and won't move you may have knocked the linkage loose. It just snaps back on but you need to make sure what it is causing the problem first.
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
May 6, 2004
  • May 6, 2004
this may sound simple but try to play with your steering wheel while trying to put into drive if you havn't already done so..
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • Gulftown980x
  • Jul 29, 2026
squeak93
