Ummm...not neccesarily. Just basic mechanical inclination and a decent Craftman socket set. All I needed anyway...Kilgore Trout said:You will not need to pull the engine. You will need however, the skills and tools of a professional mechanic...
Kilgore Trout said:Like I said, skilled mechanic ^
Yes...I wouldn't suggest just anyone jump into a cam install. But if you have some basic knowledge you can get it done.03ghoststang said:no you wont...but you will require good mechanical knowledge on what your doing
coramprat said:Yes...I wouldn't suggest just anyone jump into a cam install. But if you have some basic knowledge you can get it done.
streetstang03 said:
It depends. If you are installing cams with the same timing as the stock ones you can use the Anderson tool or the Ford cam-changing tool. This makes the job a lot easier. That is what I used and it was simple. However, if you are changing the cam timing you will need to dissassemble the front of the engine, but not remove it.kyles03sonicgt said:To install cams, do you have to pull the motor?
Just the accessories and the crank pulley. That is to get to the timing cover.Mel96GT said:It depends. If you are installing cams with the same timing as the stock ones you can use the Anderson tool or the Ford cam-changing tool. This makes the job a lot easier. That is what I used and it was simple. However, if you are changing the cam timing you will need to dissassemble the front of the engine, but not remove it.
