  • SN95 4.6L Mustang Tech
Install on Cams?
  • Thread starter Thread starter kyles03sonicgt
  • Start date Start date Dec 6, 2005
First Prev 2 of 2
M
MatthewP
355
Calgary, Alberta
Dec 8, 2005
#21
  • Dec 8, 2005
  • #21
Re: the questions about exhaust with this change:
- The heads can be removed with the factory manifolds attached, no problem.
- I installed Bassani "mid length" headers with a head swap. You can drop the passenger side head in with the header primary tubes (but not the collector) bolted up. You can drop the driver's side head in with three of the header primaries bolted up, and put the final tube on after you have the steering shaft in place.
Putting the heads on with the headers attached makes this whole job a lot easier, especially on the passenger side since you don't have to pull the starter.
-Matthew
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 8, 2005
#22
  • Dec 8, 2005
  • #22
kyles03sonicgt said:
Hey 03ghoststang, I noticed you have stage 1 VT cams. Are you completely satisified with them? Do you wish you would have went with the stage 2's? Are you also happy with your sound at idle? Thanks - Kyle
i havent gotten them yet the shop i order them from has them but i havent gone to pick them up. I went with the stg1's cause it will make it easier to pass emissions with the stock H-pipe
First Prev 2 of 2
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
D
Help Identifying cam
  • dropteeth
  • Oct 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
dropteeth
D
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Y
Dash cam
  • yankeyfan02
  • Sep 15, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 18, 2026
horse sence
