Installation of mechanical temp. gauge...
More info will help. Mouting will depend upon the length of capillary tube - if it is 6', you are a little limited.
I put mine in the stock temp sender location and relo'd the stock sender to the rear port on the driver-side lower intake.
Good luck.
wht93gtEd said:
Why not go electrical?? Isn't that much easier?
I prefer mechanical because they generally have a greater needle sweep and are not as likely to fall dependant upon charging system fluctuations.
