  • 1994 - 1995 Specific Tech
installed chip today...no start
  • Thread starter Thread starter FlyBy763
  • Start date Start date Oct 14, 2005
FlyBy763
439
Palm Bay, FL
Oct 14, 2005
  • Oct 14, 2005
Tried installing my chip today, nothing. Car turns over but wont fire. I cleaned the port real well, used a little sand paper too. When I turn the key on the cooling fan comes on and the fuel pump runs and doesnt stop...
I took the chip out and the car runs fine...any ideas?
rustang94
281
Milwaukee WI.
Oct 14, 2005
  • Oct 14, 2005
Is it a switch chip? Brand?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 14, 2005
  • Oct 14, 2005
To me ...... Sounds like
PCB contacts are not clean
or
Chip is bad
Has this chip worked for you before?
Grady
FlyBy763
439
Palm Bay, FL
Oct 15, 2005
  • Oct 15, 2005
First time ive installed the chip....
its a Diablo Sport Revolution
Don 95Vert
1,091
Delaware, OH
Oct 15, 2005
  • Oct 15, 2005
Did you clean BOTH sides of the EEC connector? If not you may have a mess on your hands because the chip will have that grease all over it now. Hopefully, after snading you cleaned it all with alcohol and a rag. The other possibility is you sanded it too much and worn down the connectors...
I'd wager the port still isn't clean - but it could (very rare) be a bad chip...
mytight95
2,605
Dothan,Al
Oct 15, 2005
  • Oct 15, 2005
i would use some 0000 steel wool, rather than sandpaper.........it seemed to be less messy and still take all the film on the connection off..
jason
CManT1914
3,172
Killeen, Texas
Oct 15, 2005
  • Oct 15, 2005
The J3 port isn't clean enough. The constant fan and fuel pump are signs of this. Keep scrubbing with an eraser.
mytight95
2,605
Dothan,Al
Oct 15, 2005
  • Oct 15, 2005
eraser? will that actually work.....
jason
FlyBy763
439
Palm Bay, FL
Oct 15, 2005
  • Oct 15, 2005
Cleaned it about as good as I can...still nothing...same thing as before. I dunno, guess Ill talk to the tuner..
CManT1914
3,172
Killeen, Texas
Oct 15, 2005
#10
  • Oct 15, 2005
  • #10
jason
Yep, that's what I used.
94MustangGT5.0
288
Champaign, Illinois
Oct 16, 2005
#11
  • Oct 16, 2005
  • #11
I have had similar problems, except mine starts just won't run at idle. I took the chip out, the problem stopped, then I put it back in after cleaning it thoroughly, and I still occasionally get the problem of it not running at idle. Make sure there is nothing on the terminals of the chip as well, just in case something got caught in it.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
H
Engine 1992 mustang LX starting issue
  • Hdbandit
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
General karthief
  • dan50
  • Jul 18, 2026
dan50
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
