  • SN95 4.6L Mustang Tech
installed mongoose kit...now problems. whats wrong?
  • Thread starter Thread starter predator_96817
  • Start date Start date May 9, 2005
P
predator_96817
133
  • May 9, 2005
ok a few days ago i finished the install on my 03 GT. the car was running ok with Tims tune but the tune was off. i think it was for a manual. he send me another tune to fix my speedo/tranny problems but now the car is acting messed up. when i start the car, black and also white smoke comes out of the tailpipes. there is a strong smell of gas also. car sounds like its being flooded with gas. it doesnt idle right and dies. this happened the first time i started the car with the first tune but when i plugged the air hose that goes from the inlet to the discharge(i forgot to do it) and started it again, it smoothed out to normal. now its all jacked up again. oh ya, i also noticed that one of the wires that lead to the maf has been cut a little by metal edges in the engine bay. when i moved the wires, it sparked against the metal. (car was off but key set to on position). did i mess up my maf? is it the tune? could the plasma booster be messing up tims tune somehow? help anyone!
Spreadman
two wheels
Houston, TX
May 9, 2005
  • May 9, 2005
If you didn't notify Tim of the plasma booster, then yes, there will be issues.
You need to fix those wires asap, and it might have shorted out the MAF. Or could have shorted something in the computer.
You should probably post your issue in the appropriate forum at Tim's.
http://www.modularpowerhouse.com/forums/forumdisplay.php?f=32
That's the Mongoose Kit forum.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 10, 2005
  • May 10, 2005
BTW i love your avatar.
P
predator_96817
133
  • May 10, 2005
ok, will try disconnect plasma booster asap. the wires is not cut completely. its just cut to the metal. would there be any other issues if there was something wrong with the computer? is there a fuse that could be broke? i already posted at modularpowerhouse, waiting for responses. thanks for info
DeadLurker
Daily Driven
Sep 7, 2001
7,702
New York
May 10, 2005
  • May 10, 2005
x2
W
WOT
2,817
Regina, Canada
May 10, 2005
  • May 10, 2005
DeadLurker said:
x2
x3
P
predator_96817
133
  • May 13, 2005
ok, changed the maf. still the same. car runs bad, black smoke, smell gas, eventually dies if i let it idle for a few minutes. now i want to cry. can someone who knows for sure tell me if its possible that i have damaged my computer? i mean is it possible to just mess up the part that goes to my maf? i checked all my fuses with a fuse checker device and they are register. im not sure what is meant by repairing the wire. its not cut all the way. just grazed the metal part inside the plastic. please someone help me out
W
WOT
2,817
Regina, Canada
May 13, 2005
  • May 13, 2005
Call and talk to the man himself he will fix it up.
jstreet0204
939
Winston Salem, NC
May 13, 2005
  • May 13, 2005
Are you sure you have installed the chip good? Cleaned the contacts really well? I am going to dissagree with everyone else about the plasma boster causing an issue with the tune, since I don't see where any adjustments would need to be made for it.
P
predator_96817
133
#10
  • May 14, 2005
  • #10
OMG, it WAS the tune again! i installed the first tune he sent me and it ran fine. only this time the idle didnt seem as smooth and the exhaust bubbled alot. can anyone tell me what this means? anyways, it was ALOT better than the second tune but i cant use it cuz the tranny is messed up on the first tune. wow, this is very irritating... i was told that tunes can get messed up by being emailed but i didnt think it would be everytime... i know he is real busy so...oh well
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
