Stang and 2 birds, doesn't the fan touch the radiator and fins? Haven't quite found how to float mine and still make it effective...
No factory fan or shroud touched the radiator fins. And, do not use a foam gasket! Sigh, more interweb BS.
Just use/make some angle brackets.
Also, Summit has some very nice
brackets that also work well for installing most electric fans with full shrouds onto radiators.
These brackets slip right over the edge of the radiator flange - similar to how the bottom stock fan shroud bracket clips slip over the bottom on the radiator flange.
Be Cool 72054 - Be Cool Electric Fan Module Mounting Brackets - SummitRacing.com
Note that ~$3 angle brackets (with an extra bend added) from Home Depot or Wal-mart also do a perfectly fine good job!
i.e. (extra bend at the top)
Code:
| (start of added bend)
| (<- Mount to radiator here)
| (end of added bend)
| (<- Mount to fan shroud here)
FWIW: When I was a teenager, my radiator lasted about 2 years.
(In my defense, that was before I started any of my real Mechanical Engineering classes.
Anything from a 0.10" to 0.50" gap between the shroud and the radiator should be fine. For brackets done by people (i.e. not from the factory), I like a gap of ~0.20". That allows for plenty of shroud and bracket flex, yet allows very little air seepage in. The amount of air flow going in from that size gap will be minimal.
BTW: While semi-on the topic,
for mechanical fan blade location and shrouds:
In a mechanical fan setup, the "near ideal" location for the fan blades are so that they are ~1/2 into the edge of the fan shroud. But, as long as the mechanical blades go past the outer edge of the fan shroud, they are likely okay. If they are too far in the shroud, then there is wasted energy (and less air flow) by having the fan move the air out from the shroud.
IMHO, having a mechanical fan too far
inside the shroud is of little concern. It's when the mechanical fan blade tips are over 0.5"
outside from the fan shroud, that a lot of air flow being drawn through the shroud is lost.
Good Luck!
